Flywheel "Hot Spots"???
Old Feb 12, 2009 | 05:16 PM
canucklehead's Avatar
Question Flywheel "Hot Spots"???
can someone please explain what "hot spots" look like on an OEM (or any) flywheel? also, what is glazing?
i may be purchasing a lightly used flywheel from a friend. after inspection i see there are 3 small (~1.5" long, ~.5" wide, 120 degrees apart - equal spacing) spots on the flywheel that are somewhat smoother & shinier than the rest of the surface. the wear surface has small grooves, expect for these 3 spots that are located closer to the inside of the contact area. these are not high spots, and they are not discoloured.
everything else looks fine. looking at the grooved surface on the outside of the wear area, the flywheel shows almost no wear. i assume the flywheel metal wears similar to a brake rotor.
i know this is probably a difficult question to answer. i hope i have explained it well enough...
Old Feb 12, 2009 | 05:58 PM
superchargedg's Avatar
They are overheated isolated parts of the flywheel....but just take it to a machine shop and they should be able to clean it up.
Old Feb 12, 2009 | 06:33 PM
^ yeah, i phoned a machine shop. they said it sounds like "glazing" which can be cleaned up with a resurfacing. there's still lots of friction surface left. i'm taking it by the place later on...
AL8782
Oct 3, 2015 10:26 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
wayneside
SouthEast
Sep 23, 2015 06:38 AM
