rpm's
Old Mar 17, 2009 | 10:23 PM
04REDcoupe's Avatar
rpm's
Been a LONG time since I posted,but here goes . while going lets say 60, in 6thgear and I give it gas to go .....65. the engine revs up but the car hesitates, it dosent jerk , but the tach revs up, then drops back down, THEN the car speeds up to the intended 65, anyone have this problem??? and whats up??????
Old Mar 17, 2009 | 10:57 PM
1ceman's Avatar
Your clutch is gone.
Old Mar 17, 2009 | 10:59 PM
04REDcoupe's Avatar
even if it shifts perfect from 1st- all the way up???? and there is NO hesitation at all and it drives like it has since we bought it,
Old Mar 18, 2009 | 08:29 AM
04REDcoupe's Avatar
Let me re-explain the situation.while going lets say 60, in 6thgear and I give it gas to go ..... lets say 65.the car speeds up,the tach goes up, and then the tach goes DOWN !!sorry about the wrong explanationof the problem
Old Mar 18, 2009 | 09:00 AM
SPEC-01's Avatar
Even the second explanation leads me to believe that you are experiencing clutch slip. If the RPM's increase at a rate that isn't proportionate to the increase of speed then the clutch is slipping. I know this may not be what you wanted to hear but it is the most likely cause of your issue. Let me know if you have any questions about clutch and flywheel recommendations and I will be happy to assist you further. Thanks!
Old Mar 18, 2009 | 09:02 AM
JBF's Avatar
JBF
definetly clutch. I had the same problem, replaced the clutch, no problem!
Old Mar 18, 2009 | 09:16 AM
uf20wop's Avatar
clutch
Old Mar 20, 2009 | 09:25 AM
04REDcoupe's Avatar
thx for the quik reply's, I pretty much knew it just need to get some more thoughts .
Old Mar 20, 2009 | 10:51 AM
gwilli3272's Avatar
That is pretty much what just happened with my 05. Flywheel and clutch pack = $1500
The stock flywheel I was told is right in the neighborhood of $1K by itself.
06g35
Feb 14, 2022 05:59 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
alessandro
Oct 8, 2015 09:29 AM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
