Double Clutching???
#32
#33
everthing i have read, and the youtube instructional vids on proper downshifting - road racing say double clutching is not needed with new car trans.
Sounds like it would wear your trans parts quicker. And dont use your trans to slow down through downshifts that is the incorrect way to downshift.
Brakes are cheaper than trans parts, use the hell out of them.
Double clutching heh you were watching F&F 1 werent you, caught cha!
#34
What sort of magical device in the transmission is "locking you out of first?"
Never seen that in any manual transmission...
BTW - if you could double clutch correctly, you'd see this isn't true because you'll be able to select first at higher speeds with a good selector speed match.
#36
First gear is useful in some tight autocross courses, unless you think bogging away from a very tight decreasing radius hairpin in 2nd at 10 mph is fast...
#37
That's just the design of the synchros making them not work well on first gear with high selector to intermediate shaft speed differentials.
Ninjay16
Audio/Video/Electronics
11
02-26-2018 06:14 PM
