Stuck in 4th gear?
Old Jan 2, 2016 | 04:24 PM
Nomokofous's Avatar
My problem went away when I changed my transmission. It shouldn't cost much. I had a transmission from the junkyard for $500
Old Oct 11, 2017 | 12:38 PM
Joey Gauthier's Avatar
I need help any information you could share would be awesome
Originally Posted by zdavid408
Any one need help on this? i know what goes bad. LMK. Ill help.
I would love some help on this PLEASE . I just had a push start put in from starter failures now this please help me
Old Oct 11, 2017 | 10:13 PM
Blue Dream's Avatar
I drove ttrank's car solo
He hasn't logged on here in over 2 1/2 years so I doubt you're going to get an answer.
Old Sep 15, 2018 | 09:46 PM
Alfred Greco's Avatar
M
DUDE, same **** happened to me, the D was stuck there. Yes your mechanic is right something did get wet. A relay to be accurate!. The bad relay is located next to the computer (on the passenger side, by the feet), it is a blue color one water somehow gets in it thro the hood vents, mine leaved cuz i had a sub wires installed and the water went thru that. If you need pictures or more help, just let me know.
My 03 g35 sedan is stuck in 4th. Can u please send me pics where you said that relay of your got wet plz. Thanks
Old Dec 7, 2019 | 11:11 AM
Gabe Puzon's Avatar
03 g35 coupe
lol pls^^^
Old Feb 3, 2020 | 05:49 PM
Rainy's Avatar
2005 G35 Coupe loaded but bone stock!
Check your engine codes, this is probably the common Front brake solenoid in the valve body gone bad, or the circuit is cracked., code P1757. There are several great youtube vids that show how to diagnose and fix it, it's common on this transmission in Nissans and the occasional g35. The car locks into limp mode and will not come out of 4th gear for anything.
On mine, sometimes it will drive and shift ok for a bit then lock out. I can sometimes get around it by manually shifting it but it will always eventually lock into 4th.
I just bought a 05 G35 coupe with this issue too for an insanely low price. Should be an easy fix, at worst it needs a new valve body.
Old Feb 3, 2020 | 05:52 PM
Gabe Puzon's Avatar
03 g35 coupe
Fixed
Originally Posted by Rainy
Check your engine codes, this is probably the common Front brake solenoid in the valve body gone bad, or the circuit is cracked. There are several great youtube vids that show how to diagnose and fix it, it's common on this transmission in Nissans and the occasional g35. The car locks into limp mode and will not come out of 4th gear for anything.
I fixed mine, hopefully the other guy did. Made a thread on the whole process https://g35driver.com/forums/showthr...3&goto=newpost
Old Mar 25, 2020 | 09:36 AM
Bruce Turner's Avatar
G35
chang the blue relay on the side of the tcm it fixed my 03 get Coupe
Old Feb 20, 2022 | 05:07 PM
Zanku Ryiple's Avatar
G35
Originally Posted by CarolynT1021
My boyfriend is having issues with his G35x. His automatic running light sensor blew, and it took out the battery. When he went to start the car before realizing the battery was dead, the lights on the dash were surging/ pulsing. Saw the battery was dead, got a jump, and now the car is stuck in fourth. The manumatic float shifts, changes the display of the gear, but no change otherwise. Park, reverse, and neutral are fine, but as soon as you put in drive, there's a large "thunk" in the back and the car sounds almost like the exhaust is gone when driven below 40 mph. I would appreciate a picture of the relays and location, what you replaced, and the name of the specific relay. Please help!
Mine just started doing this exact same thing. The codes read "Foward Brake Syoloid". When I went to get diagnosed they said they would need to change the transmission and wanted $3500 for the service. What did y'all do to fix it? And please say it was cheaper than that. I'm thinking of getting a buddy of mine who's a mechanic to just get a transmission from the local pick and pull to see if that works.
Old Feb 20, 2022 | 05:46 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Why not just change out the $20 front brake solenoid instead of replacing the entire transmission?
If your cam sensor goes out would you replace the entire engine?
Old Feb 22, 2022 | 03:56 PM
Gabe Puzon's Avatar
03 g35 coupe
Mine was just a blue fuse hidden behind the passenger kickboard trim(to the bottomleft of the passenger door if viewed sitting in the passenger seat). Ended up getting wet due to the rubber grommet protecting water from going past the firewall into the car not being placed in properly by the previous owner. So probably not your problem unless u had water intrusion issues.
You could probably do it at home yourself and save some money.. drop the trans oil pan remove the circuit board, replace the solenoid and check the board for any damage, replace that if need be or re-solder any bad connections. Sounds like the shop doesn’t know wtf they’re up against so they’d rather sell you a whole *** trans to avoid complications. You could also take it to a trans specialist shop and your car would probably be better off. If you wanna DIY you can look up the procedure… there’s this which might be helpful:
Old Feb 24, 2022 | 09:48 PM
G35
Old Apr 9, 2022 | 11:19 PM
Fatherof2.25's Avatar
Infiniti automatic
my car feels like it's stuck in 4th gear please if you could help me this thing is Godless G35
Old Apr 10, 2022 | 11:45 AM
cleric670's Avatar
BANNED!!!
Scan the car and see if it's throwing any diagnostic codes.
Old Jun 27, 2024 | 08:01 AM
  #30
GREATMANN's Avatar
g35 infiniti
My transmission stuck on4th gear. It won’t take the 5th one
Any one need help on this? i know what goes bad. LMK. I’ll nd help.
do you know the reason it stuck on 4th gear because I put new valve body , all the solenoids and the speed sensor that’s located inside the transmission. And I don’t have any codes. But the problem still the same ! Can you help !? Or any idea what could be wrong. Thank u
jtesh96
May 11, 2018 03:30 PM
jtesh96
Apr 12, 2016 09:45 PM
Dat Kid
Nov 23, 2015 11:18 AM
johnnyqt25
Drivetrain
May 24, 2013 01:11 AM
MinkG35
Drivetrain
Oct 9, 2008 05:05 PM
