Transmission Slip
Old Sep 22, 2009 | 03:30 PM
  #46
GreekPimpSlap's Avatar
Just to update everyone:
brought the car to a reputable tranny shop in MA. they checked it out and said something about the clutch packs being gone which is typically the result of the computer inside the tranny malfunctioning. the cost to repair is going to be in the $2500-$3800 area. He said he would be able to tell me more specifics tomorrow when he actually rips the thing open to see how much damage has been done and determine what he will have to replace.
Just out of curiousity i called the dealer to see how much they would charge to do the work and they said that they wouldnt replace the clutch packs or the computer, rather they would suggest installing a new tranny (go figure) which would cost in the neighborhood of $5000-$6000.
If i get more info from the transmission place ill update you guys
Old Sep 24, 2009 | 02:07 PM
  #47
well, the transmission shop just called back and told me that the computer inside the tranny malfunctioned which caused low pressure on the clutch packs and ultimatly caused the clutch packs to burn out. I was given the following 2 options:
#1 Replace the damaged clutch packs, computer, and valve body inside the transmission for $3200. This came with a 1yr/12K mile warranty
#2 Replace the whole transmission with a completely (ceritifed?) rebuilt transmission for $3800. This came with a 3yr/36K mile warranty
I opted for option #2 as i plan to have this car for another 3 years and really like that warranty. The car should be ready by tomorrow night.
Man, what a to the wallet
Old Oct 20, 2009 | 06:18 PM
  #48
NavEngineer's Avatar
How's the new tranny doing? I know it's only been a few days. I'm having this same problem and I really hope I don't need a new transmission. My car is still under warranty (06' 5MT coupe), so I'm taking it to the dealership tomorrow!
Old Oct 25, 2009 | 06:42 PM
  #49
silver64bh's Avatar
same exact problem here
i still can see that nobody has found the solution
please let me know if you found any solution for the problem because it is making me crazy...
Old Nov 7, 2009 | 01:40 PM
  #50
siksek's Avatar
i thought im gona be alone on this 1, 2008 G35 with 36K on it , car has always been driven hard , and i had to slow down in the past week due to tire issues , and thats when i noticed the issue , im sure its not clutches as they tend to slip under throttle and high temps , this happens with cold starts and low rpm's so for sure it has to do with transmission fluid and the TC , i parked the car at the dealership and will go to test it out first thing in the morning when its cold , will keep you posted
infiniti changes the whole gearbox under warranty here, fingers crossed !
Old Nov 12, 2009 | 03:00 AM
  #51
yonsei21's Avatar
Transmission codes coming on
I took my '04 g35 in because the tramsmission feels like it is slipping starting in park. The dealership shows transmission codes and said may need to replace valve body($1400). Does that sound right? I have 90,000 miles on the car.
Old Nov 12, 2009 | 11:31 PM
  #52
docbong88's Avatar
I have that problem, but also another problem as well.
When i'm cruising in traffic (and in traffic only), at about 10-15 mph, and want to give it a little gas the rpms will go from 1k to 1.5k before the car actually starts moving. Any ideas?
Old Nov 13, 2009 | 03:16 AM
  #53
pfarmer's Avatar
Torque converter not locked up.
Old Nov 13, 2009 | 09:41 PM
  #54
docbong88's Avatar
Thanks, but i'm not sure exactly what that means.
Also, i noticed it seems to be happening when i'm cruising downhill, and when i give it the tiniest bit of throttle, it seems like the engine is revving up to catch up to the speed the car is traveling, IF that makes sense.
Only notice this in heavy traffic stop and go
Old Nov 17, 2009 | 04:07 AM
  #55
G35 Mass's Avatar
What tranny shop did you go to? I have to have some serious work done to mine....
Old Nov 17, 2009 | 05:16 AM
  #56
pfarmer's Avatar
Think of your torque converter as a clutch. Until it locks up your engine rpm can vary with load without any change in speed. Once locked up it will tend to change with speed. Sort of the difference between a clutch that slips and one that is fully engaged. If you torque converter stayed locked up it would stall your car when you came to a stop. This actually has been a problem with some older cars when torque converters were first designed to do so, I think some Chryslers had this issue when fuel economy first became a big issue.
Some cars lock up at a magic mph, others do the same but will kick out based on throttle position (I think most will do this now anyway), others will lock up based on current gear. For at least some Infinitis this has been stated as in 4th and 5th gear (note the quote below in regards to 3rd, 4th, and 5th gears). Considering the speed when you are in this speed range it may well be the non-issue many have reported with their cars stumbling at certain speeds, that is the transmission moved or is moving in between lockup and non-lockup torque converter modes. You can see some of this effect when using the manual shift mode.
From the 2007 FSM -
Lock up occurs at Closed throttle 31-36 mph, released 29-34 mph
Lock up occurs at 1/2 throttle 86-91 mph, released 65-70 mph
Also:
Slip Lock-up Control
• In the slip region, the torque converter clutch solenoid current is controlled with the TCM to put it into the
half-clutched state. This absorbs the engine torque fluctuation and lock-up operates from low speed.
This raises the fuel efficiency for 3rd, 4th and 5th gears at both low speed and when the accelerator has a
low degree of opening.
Old Nov 18, 2009 | 06:54 PM
  #57
docbong88's Avatar
Is this normal for this car? I have an 03 g35 coupe. I can't say for sure but i think i've only started to notice this happen in the last couple months. Could it be transmission slipping?
Also, don't know if this is related but recently i got a drain and fill, and my mechanic told me the AT fluid level was at least 1/2 a quart overfilled, and i've been driving with that for 20k miles.
please, need help solving this issue. thanks!!
Old Dec 12, 2009 | 12:08 AM
  #58
ransick's Avatar
2003 5AT slipping needs new tranny
Last week my tranny starting slipping in 5th gear. Going 45mph ~2k rpms on a flat road, gave it a slight increase in gas and the rpms increased, speed didn't. Ran several experiments and they were all the same, unless I slammed the gas so the car down shifted or manually shifted in to 4th gear.
Took it to the dealer and they said I need a new transmission. Luckily I bought an extended warranty and it is covered but WTF. I use to tease my wife about the quality of her Chrysler minivans but they have never had transmission failures and we keep them past 100k miles.
2003.0 5AT 89k miles
I was planning on keeping it until ~175k miles. Now I'm not sure. Why would the new one last 100k miles if the original one didn't?
Old Jan 18, 2010 | 09:34 AM
  #59
Maciuniu's Avatar
Originally Posted by Lucky-G
I get nearly the same problem. When the car is shifting from 1st to 2nd or 2nd to 3rd it ocassionally shudders like a slipping clutch. I'll be replacing the tranny fluid very soon and I'll update the status of my car. If I put my foot down (around 70% throttle) it never does it. Usually around 20-30% throttle is where I experience the shudder. I've never experienced the 45mph shudder either.
*sigh* The issue makes me worry about running the car down the 1/4mile, or even strapping it to a dyno, in fear that the tranny will grenade
Same problem that i am having 04/coupe 60K miles
Old Jan 13, 2011 | 10:39 PM
  #60
adilSD's Avatar
Looks like I am not alone. Mine is a 2007 G35S at 56kmiles and I observe/reproduce this when accelerating steadily, about 25% load, when the AT shifts from 3-4.
The RPM drops about 200, goes back up 200, then drops to whatever the 4th should have at that speed.
Is there a TSB on this? How do I explain this to my service manager?
If there si something wrong with the TC or TCU, I would like to get that fixed before I am out of warranty. Any hints or help?
Thanks,
Adil
f22raptor
Mar 18, 2016 08:50 AM
markbilo
Sep 30, 2015 01:33 AM
vamarris
Sep 26, 2015 12:56 PM
