DIY: Differential Fluid Change
Old Feb 15, 2011 | 12:16 PM
  #31
ShaneH85's Avatar
well man i changed mine and i had no shavings.. maybe it just happens on some of them, and maybe its worth taking the diff cover off to have a look at the gear? I hope for the best, never like to see a fellow g owner having problems with their ride
Old Feb 15, 2011 | 12:18 PM
  #32
thescreensavers's Avatar
Mr.202?
Mine had a little black gunk on it, Mine held 1.5 quarts dont know why OP says 3.
Old Feb 15, 2011 | 12:20 PM
  #33
ShaneH85's Avatar
bc the dumb *** at my local dealership said three.. i need to fix that, thanks
Old Feb 15, 2011 | 02:52 PM
  #34
a471133's Avatar
Yeah, what Shane said is true. My fluid was clear, and the metal shavings were only on the tip of the magnetic bolt only, so I feel safe for having 60K+ on the car. If your used fluid has any particles, or the bolt has alot of shavings, better open it up and take a look. Better safe than sorry.
Old Feb 15, 2011 | 03:03 PM
  #35
surma884's Avatar
Originally Posted by mkvl127
i have an X and on the amsoil website it says use oem fluid for the transfer case..now is there 2 diffs and a transfer case?..so ill do both front and rear diff with amsoil and the transfer case with oem nissan fluid???
Yes, I believe so. The transfer case takes the power from the transmission and sends it to the front and rear axles (diffs). So the front and rear diff can use 3rd party fluid, and the transfer case would use the OEM fluid.
Old Feb 16, 2011 | 03:28 AM
  #36
monsta717's Avatar
this goes for 4Door and 2 Door also?
Old Feb 16, 2011 | 11:25 AM
  #37
brandon1978's Avatar
Yes. Coupe and sedan drivetrains are the same.
Old Mar 20, 2012 | 10:34 AM
  #38
Oogie Boogie's Avatar
Does anyone know if we should use a LSD additive?
Old Mar 21, 2012 | 04:54 PM
  #39
Don't use an LSD additive in the stock diffs. The part that makes the stock differentials have limited slip is the viscous coupling. The viscous fluid is inside the coupling and can't be changed.
Old Oct 17, 2013 | 09:53 PM
  #40
PokerPlayer's Avatar
G35 Transfer Case
I have a 2006 G35 coupe (RWD) and the dealership recommended I have my transfer case fluid changed along with my rear differential fluid (140,000 km service).
I thought transfer case would only apply to AWD vehicles?
Is there a transfer case for my RWD vehicle and if so should I have the fluid changed?
Any thoughts on auto transmission flush at this mileage?
Many thanks!
Old Oct 18, 2013 | 10:56 AM
  #41
Texasscout's Avatar
Be sure to change the gasket on the drain plug. I didn't on my second drain/fill and now I have a drip that will be a PITA to fix.
Hawk196
Sep 22, 2015 02:51 PM
JoeMac
Aug 20, 2015 10:17 AM
Blakearold
Aug 19, 2015 10:20 AM
linedr89
Aug 17, 2015 05:11 PM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
