Humming noise from the rear end
Old Nov 18, 2010 | 03:27 PM
Clob's Avatar
Hey all. I just got a used '04 coupe 6mt fully loaded.
I noticed that the highway noise is quite high. I'm not sure what it is, but a moderately loud humming noise is coming from the rear when on the high way. The faster I go, the louder it gets. How can I tell if its tire noise or something else, like the rear diff or a bearing?
I sure hope it is the tires
These are the tires that are on it front and back. They are a bit worn and I'm looking to replace them.
BF Goodrich g-Force T/A
http://www.bfgoodrichtires.com/tire-...Y/tire-details
Old Nov 18, 2010 | 07:52 PM
xWRECKo's Avatar
You should check your tires and make sure that they are not cupping. It is really common on these cars. It is caused by the alignment being off. I have the same problem in the front when I first go my used 04 G35 coupe.
Old Nov 19, 2010 | 09:06 PM
0me6a7's Avatar
it could also be the wheel bearings.
Old Nov 21, 2010 | 10:30 PM
butkiss1's Avatar
Thats what i just replaced, same humming sound
Old Nov 21, 2010 | 10:39 PM
Clob's Avatar
Geeze. Any idea of the cost for the parts?
Old Nov 21, 2010 | 11:12 PM
butkiss1's Avatar
Was not too bad ....... 200 or so.
Old Nov 22, 2010 | 12:59 AM
Tollboothwilley's Avatar
Sounds like a wheel bearing to me...but very worn/bad tires can cause similar issues too.
Old Nov 22, 2010 | 11:54 AM
Clob's Avatar
Well, AutoZone has wheel bearings for $70. Labor is no issue. I feel like I'm getting ripped off on tires in my local shops. No one carries the stock 245 45 18, or they want $200 / each... What to do. I made the stupid mistake of buying the car and not demanding tires to be put on it....
TireRack seems to be a favored here...
Old Nov 28, 2010 | 10:50 PM
bluedevils95's Avatar
I hear that humming noise on my 08 sedan coming from the middle of the car on passenger side. I don't hear it too often though
Old Dec 16, 2010 | 12:54 AM
SilverMamba's Avatar
how tough is the wheel bearing install? I am having the exact same problem. any special tools?
Old Dec 16, 2010 | 12:56 AM
Clob's Avatar
It turns out it was the tires. They where in a real bad way...
Muski_G
Dec 1, 2023 11:11 AM
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
Ken167
Aug 7, 2015 11:12 AM
atk08
Jul 30, 2015 03:12 PM
