humming noise from my diff
Old Dec 9, 2010 | 11:37 PM
g35oahu's Avatar
2004 g35 coupe
when driving i'd say over 35-40 mph + i have this road noise or humming noise coming from i'm assuming my rear differential. at first i thought well its the tires but there brand new. and then the noise decreases as speed does and increases and speed increases.
what could this be a sign off? diff rebuild? bad diif oil?
i'd appreciate any suggestions. Thanks in advice
Old Dec 10, 2010 | 07:05 AM
grovefromnh's Avatar
If the new tires are from a different manufacturor, it could be them.
Old Dec 13, 2010 | 01:37 AM
g35oahu's Avatar
all 4 tires were replaced at the same time..same manufacture
Old Dec 13, 2010 | 01:54 AM
thescreensavers's Avatar
Mr.202?
when was the last time you changed the fluid in the diff?
Old Dec 21, 2010 | 11:37 PM
CBRworm's Avatar
20 Year Member
Wheel bearings? The rears sound like they are coming from the differential.
Old Dec 31, 2010 | 09:30 PM
AARONHL's Avatar
How can you tell if it's the rear dif or rear wheel bearings?
Old Feb 8, 2011 | 02:32 PM
3maxima's Avatar
I have this noise too and I changed the dif. oil and the drain plug had a lot of metal on it. The noise did not improve even with synthetic. If I get new differential with my aftermarket warranty and upgrade to LSD will I have to change axles?
Old Feb 10, 2011 | 10:15 PM
nicksac's Avatar
I have the exact same problem. 98Kmiles on my 2004. Will post back when I have a resolution.
Old Feb 11, 2011 | 05:39 PM
3maxima's Avatar
I am taking mine to the local Nissan dealership Monday.
Old Feb 11, 2011 | 05:57 PM
DaveB's Avatar
If it is the diff, do not waste your money rebuilding it. You can buy used ones for $300-400. I bought my 3.5 VLSD diff with 40k miles from a local auto recycler in Topeka for $300 and swapped it myself in 3 hours. It's easy. There so few rebuilders that can get the gears to seat right without noise and you can be assured it will cost you way more than $300.
Old Feb 12, 2011 | 12:12 PM
3maxima's Avatar
DaveB were you able to reuse the same axles?
Since mine is going to be a warranty (aftermarket) repair I'm not sure how much control I have over how the repair is done.
Old Feb 12, 2011 | 01:16 PM
vp-g's Avatar
I have the same noise under acceleration in second gear it is most heard. the faster I go the noise goes away. mine is an 03 85k imles.
Old Feb 12, 2011 | 01:39 PM
Sylvan lake V35's Avatar
Yes you reuse the same axles.
Typically the humming diff means low oil. Or bad wheel bearings, to tell if it is your bearings Jack up your car and try to wiggle the wheel side to side if it moves you may need your bearings replaced.
Old Feb 23, 2011 | 10:21 AM
3maxima's Avatar
OK, the noise I thought might be the differential turned out to be the right rear wheel bearing. It's replaced now and all is well. The junk that came out of my differential still concerns me so I am going to change to fluid again real soon.
Old Feb 23, 2011 | 10:28 AM
vp-g's Avatar
how much play did you have on your rear wheel? did the noise go away the faster you go or just got louder? I am still trying to find out my issue.
