Differentials????
Old Mar 1, 2011 | 02:46 PM
Eric@TCGMiami's Avatar
Differentials????
Looking to purchase one from a local shop, I spinned the part in which the drive shaft connects and both axles spin the same direction.
According to the shop it's a 2006 G35 Coupe. Auto.
Is this VLSD?
Old Mar 1, 2011 | 03:08 PM
migueralliart's Avatar
Is this VLSD?
It is supposed to be a VSLD if you spin one side and the other one spins in the same direction. So I think it is a VSLD.
I have a 3.7 VSLD out of a g37 with a 4 bolt flange that I am gonna put in the classifieds for sale.
Old Mar 1, 2011 | 03:16 PM
Ok, i spinned the drive shaft part, NOT THE WHEEL PART. and both wheels spinned the same direction.
Perhaps I need to check by spinning 1 wheel and NOT the drive shaft????
can any one confirm this?
Old Mar 1, 2011 | 04:36 PM
MikeDG's Avatar
Is this VLSD?
Someone please correct me if I'm wrong, but I didn't the 03-06 autos come with an open diff?
Old Mar 1, 2011 | 04:42 PM
DaveB's Avatar
If you turn the driveshaft flange and both axle stubs spin in the same direction, then the diff has a VLSD.
If you spin the axle stubs spin in opposite directions, then it's an open diff.
I verified this with my VLSD and open diffs. I don't know about the coupes, but in 05/06 the Sport package on 5AT sedans came with 3.34 VLSDs.
Old Mar 1, 2011 | 04:51 PM
thescreensavers's Avatar
Mr.202?
^ 3.34? I thought they were 3.5 cause my RPM are 80mph is 3k ?
I am running 245/45-18 now was running stock 235/45-18 in the thread
https://g35driver.com/forums/drivetr...ms-80-mph.html
Old Mar 1, 2011 | 05:07 PM
Sad part is id like to keep my long gears, is there anyway to keep the gearing just add the lsd into it?
Old Mar 2, 2011 | 02:25 PM
How much do 3.5 VLSD's go for ?
Old Mar 3, 2011 | 12:20 AM
Tollboothwilley's Avatar
2006 5AT Coupe with sport package has 3.53 w/ VLSD. Other than that all 2003-2006 5AT have 3.35 - G35X is the exception but this is not a direct swap anyways.
Old Mar 4, 2011 | 07:26 AM
sloppymax's Avatar
The FSM shows the 2006 auto sedan with a 3.53. My rpms at 80 match those of owners who installed the 3.5 in place of their 3.3. The FSM also shows the 3.53 for the 06 as Toll mentioned but also for the 07 auto coupes. It has been mentioned that it could be a misprint but that would be two years in a row for a misprint in the coupe FSM and my rpms at 80 are 3200 with 245/40/18 all around.
Old Mar 4, 2011 | 10:10 AM
http://infinitihelp.com/models/2006/...ifications.htm
only the 6MT for a sedan had 3.53 gears except for the G35X according to infinitihelp
http://www.nicoclub.com/FSM/G35/Seda..._Sedan/rfd.pdf (page 60)
5AT shows it was 3.53 gearing for all 2006 sedans as well according to the FSM. THe VLSD was available in the sport and was standard in the 6MT
I would go off the FSM - if you are @ 3200 rpms doing 80 mph then you should be running a 3.53 assuming your tires are not DRASTICALLY different.
Even now I have 245/40/19 all around which are too tall - and @ 80mph it only changes the rpms by 100.
Marlin84
Apr 1, 2020 12:52 PM
Dannyy06
Sep 25, 2015 11:32 AM
DRG35R
Sep 16, 2015 05:33 AM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
