tranny slipping? literally...
Old Jul 1, 2011 | 06:15 PM
buzzking's Avatar
Hey guys,
I see a lot of people talking about tranny slipping, but I'm not sure what that means!
Can someone explain please?
Thanks
Old Jul 3, 2011 | 02:36 AM
hologram's Avatar
Means that gears in the tranny when you engage to switch from one to another dont properly switch and you feel as if it didn't switch properly between the gears in the tranny.
Old Jul 3, 2011 | 11:18 AM
buzzking's Avatar
My gears switch but I hear a clunck after each up-shift. What is that called?
Old Jul 3, 2011 | 12:11 PM
faiz23's Avatar
Manual or Auto and I am guessing manual. What RPM do you up shift at and do you rev match or not.
https://g35driver.com/forums/g-spot/...-drive-mt.html
Old Jul 3, 2011 | 02:00 PM
buzzking's Avatar
I rev-match with I down-shift and that's fine.
Am I suppose to rev-match when I gear up as well?
It clunks every time I gear up!
Old Jul 3, 2011 | 02:16 PM
faiz23's Avatar
Are you skipping gears and then getting a clunk or no matter what. When was last time you changed the fluid on the tranny and what fluid was used. When I am shifting in first and go up to 2nd gear I would take my revs to say 3k and once I shift into second and before I let go of clutch I make sure my revs are in between 1900-2100 rpm and that gives me a smooth transitions. If I just up shift into 2nd and just let go of clutch without paying attention to engine sounds or rpm then i will get jerkiness or clunk. The other clunk or notchiness could be due to old fluid in the vehicle or aftermarket fluid. The differential you can use GL5 aftermarket fluid but for manual tranny it is best to stick with Nissan manual transmission fluid MTF
6mt Tranny
DIFF
Old Jul 3, 2011 | 08:52 PM
buzzking's Avatar
6mt Tranny
DIFF
I will try rev-ing even when I up-shift. The clunk was every time I up-shift without rev matching and just changing the gears. The fluids are less than 5k old and I use redline fluid for both the differential and tranny fluids!
I'll give rev-ing while up-shifting and I'll post an update.
Thanks!
Old Sep 29, 2011 | 12:19 AM
paolotonzini's Avatar
sounds like u might have a trany or motor mount problem if ur getting clunking like that might want to have it put on a lift n checked just my opinion
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
markbilo
Sep 30, 2015 01:33 AM
vamarris
Sep 26, 2015 12:56 PM
