DIY: AWD front CV half shaft removal / CV boot change
Old Jul 22, 2013 | 01:43 PM
TurTLe*'s Avatar
i normally pry there if my impact doesn't get it off on its own. but when it spinnns that much most likely its needs replacement.
still jealous of the lack of rust.
Old Dec 10, 2013 | 07:41 AM
DanPaul's Avatar
axle retaining clip
Very helpful thread. I'm into this repair right now. Like Munkle, I removed the from right CV axle and there was not a retaining clip on the shaft. I looked into front diff. and I think I can see it inside in its spot. The top picture of this thread shows an GT68's axle and best I can tell, it also has no clip. So, should I try to fish the clip out of there or should I just push the axle back in and trust that the clip will find it home? Thoughts appreciated.
Old Dec 10, 2013 | 07:46 AM
DanPaul's Avatar
Did you ever determine if there was a retaining clip for the axle? I pulled my shaft and no clip, however, I can see it in the differential. So, I'm looking for advice on whether to try and wrestle it out of there, or just slide the axle back in. I don't want to accidentally knock it out and push it into the diff.
Old Dec 10, 2013 | 01:25 PM
munkle's Avatar
Just push it in. If you happen to push the clip into the differential, you'll know by attempting to pull the newly-installed axle back out. If you cannot pull it out with your hand, you'll know the clip is in position.
When I took a new axle, front drive shaft and front diff to the Infiniti tech a few weeks ago, we laid them all out on the ground. I'd done my research and ordered all the parts (3 replacement seals) for the front differential, but there of course was no loose clip. The tech told me I needed a clip, until I pointed out that it was in the diff. He put the axle into the diff, right there in the parking lot, and it took him a minute or two of prying with a bar and a couple of our feet on the diff to remove the right front axle from the diff again. Those rings are fairly loose inside the internal channel where they rest, but they are definitely too big to be pushed into the diff or pulled back out of the diff.
Old Dec 11, 2013 | 06:32 AM
DanPaul's Avatar
CV axle retaining clip
Thanks, I'll give it a try.
Old Nov 1, 2018 | 03:22 PM
lrodptl's Avatar
Can't get mine out without a CV tool
Old Nov 2, 2018 | 04:00 PM
munkle's Avatar
You should be able to. Just spin it some while you're pulling. You'll need all five of your hands so put your beer down first.
Old Sep 9, 2021 | 07:53 PM
Dank 2021's Avatar
G35x
I can't get mine out at all no matter what I try it's the passenger side the boot ripped so I have the housing into and can't pry it out or pull it out I might be missing something
Old Sep 11, 2021 | 11:45 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
There's a snap ring on the inside, once you pry hard enough it pops the ring out.
I like to use a small prybar behind the CV housing, then slap the end of the prybar with a mini sledge a couple times.
It takes that quick impact from the hammer to pop the axle out, you can't usually just pry with your hands.
Old Nov 20, 2022 | 07:15 PM
abrecos's Avatar
Have you replaced the driver-side axle or the passenger one? I have a 2010 Infiniti G37 AWD sedan and try to find it which side axle could be pop out driver or passenger side. Thanks in advance!
Old Nov 20, 2022 | 07:46 PM
abrecos's Avatar
Is this driver's or passenger's side of the car? I try to order a replacement but am not sure which one to get. I ripped the boot on the driver's side when changing the strut and thinking about replacing it.
Old Apr 29, 2023 | 12:23 PM
LuxuryMuscle's Avatar
Originally Posted by ccc123pm
also, you reference the "transfer case" a couple times. Just to clarify, thats the front differential and the transfer case sits behind the transmission.
Actually no that is incorrect. It's actually called "Front Final Drive" per FSM.
Old Apr 29, 2023 | 01:31 PM
cleric670's Avatar
BANNED!!!
Technically you're both correct.
A final drive is just the final gear reduction before power can be utilized.
And in the case of the G35 the front final drive IS a differential which allows tires to spin at different speeds. Things like the PTO on a tractor the final drive is inside a transfer case unit since it's just spinning a shaft that you can hook equipment to.
As for the FSM they refer to the document as a front or rear final drive, and within that document they refer to the actual gearbox as a differential
Old Sep 26, 2023 | 11:04 PM
gm_gramo's Avatar
g35x
How where you able to take it out? Having same problem
adrians07z
92
Nov 6, 2024 06:11 PM
Mustang5L5
Jun 27, 2016 07:41 PM
pcfiii
Sep 19, 2015 01:32 PM
lsmooth81
Aug 31, 2013 10:06 AM
Gdup35sedan
80
Jan 31, 2012 11:26 AM
