stock drivetrain
Old Oct 22, 2012 | 01:02 PM
extremetoy's Avatar
stock drivetrain
how much power is the stock drivetrain capable of handling (the axles/ center section)
thanks
Old Oct 22, 2012 | 02:26 PM
Texasscout's Avatar
It will handle 500hp if your careful. Me personally? I wouldn't go over 425. That's JUST from the drive shaft back. The tranny is a different kettle of fish.
I don't pretend to be an expert at this, just what I have read here over the last six years.
Old Oct 22, 2012 | 05:15 PM
extremetoy's Avatar
is it the center section or the axles thant cant handle the power?
Old Oct 22, 2012 | 08:02 PM
Texasscout's Avatar
It also depends on the type of diff you have stock or Limited slip, I think the latter is a bit stronger. I do know that when the guys here get over say 600rwhp, they change out the gears on the pumpkin and the axles.
Old Oct 22, 2012 | 08:42 PM
extremetoy's Avatar
ok cool, i have a cusco 2 way lsd but with stock axles, Do you see me running into problems with about 600 rwhp?
Old Oct 22, 2012 | 08:47 PM
Texasscout's Avatar
If all you want to do is take it to the drag strip or be a stoplight bandit, yes, I see you breaking one. If you like to play in the twisties and don't launch it every time, you should be fine.
Old Oct 22, 2012 | 08:53 PM
extremetoy's Avatar
ok cool i think i should be fine then lol thanks
Old Oct 22, 2012 | 09:26 PM
herrschaft's Avatar
Just don't dump the clutch. Those who usually break axles do so at the strip.
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
toadfire
Sep 21, 2015 07:15 AM
Tonka211
Sep 18, 2015 09:46 AM
