Engine swap now transmission makes weird noise.
Old Feb 13, 2019 | 06:04 PM
JY15's Avatar
03 blue 6spd coupe
Hey all,
I recently bought 03 g35 (02/02/2019). Ive already had to do am engine swap cause a simple catch can was hiding the fact it had a cracked head gasket. So I bought a engine a d installed it this last weekend. Now I'm hearing what sounds like some kind of metal dragging across teeth as I put my foot on the gas. It's also causing a vibration that can stopped by pushing down on the shifter ****. Please help cause I really like this car but I'm really starting to regret getting it cause I've already put so money into fixing it. Thank you in advance
Old Feb 13, 2019 | 08:41 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I would start by doing a good visual inspection under the vehicle, if you can drive it down to a lube center with a pit you can get under it with a mechanics stethoscope and figure out EXACTLY where the noise is coming from.
Typically you can call ahead to see if they're busy and offer a $20 tip to stand under the car for a couple minutes to find the source of the noise, hell of a lot cheaper than paying a mechanics diagnostic fee.
Did you get all the bolts back into the bellhousing in the correct order and torqued properly? iirc there are 3 different sizes of bolts.
Sceptor
May 16, 2011 10:42 AM
dLive
Feb 21, 2011 10:55 AM
visualfxpro
Feb 14, 2011 01:33 PM
chinki grL
Sep 4, 2009 11:09 AM
kingrukus
Drivetrain
May 22, 2008 12:59 PM
