Tranny clatter at idle?
Old Mar 9, 2006 | 02:54 PM
some.devil's Avatar
Originally Posted by JDM V35
Man if you thing that is bad. I replaced my clutch and flywheel when I went Blown. I got the ACT clutch and the Nismo lightend flywheel. And boy when I sit at a light with my foot off the clutch, it sounds like a cement mixing truck.
But it all makes up for it when i bang gears!!!
mamoru!
Old Mar 14, 2006 | 01:05 AM
G35SanDiego's Avatar
Yep got the same noise. Thought about chasing the dealer up the tree with the issue but it seems to be so common that its "considered" normal. Its a shame such a beautiful car has such an ugly condition.
Old Mar 17, 2006 | 04:06 PM
OhMyG...35's Avatar
I noticed the same sound in my 05 when I was sitting at the window to Wendys! Damn glad I saw this thread I was starting to freak out about it. Former owner of 2 Acura RSX-S.....crappiest trannys ever!!!
Old Mar 17, 2006 | 04:19 PM
SweetNlow's Avatar
City that Never Sleeps
It's the new mod. Polished rocks for tranny's.
I got the same noise. I guess we will be ok. But then again I'm on my second engine...so.
Old Mar 18, 2006 | 11:10 AM
Iceman8's Avatar
yep I got the same noise and decided to just deal with it as well. Thinking my clutch bearing was going out untill this winter when my mechanic took the motor out for a build and discovered a misterious bolt just hanging out in the clutch housing! I duno!
Old Mar 20, 2006 | 05:35 PM
gersteinp's Avatar
Dual mass flywheels are supposed to be very quiet--the benefit resulting from putting up with a heavier unit. Indeed, my tranny is totally slient at idle with clutch in or out (@ 24000). There is something wrong with your clutch/flywheel and I wouldn't take any BS from the dealer. These guys are notorious for misinformation regarding warranty repairs. I would call Nissan cutomer service if I were you. The presumption should be that there is something wrong until PROVEN right by driect inspection.
Old Apr 18, 2006 | 09:58 PM
dmfg's Avatar
'05 coupe 6mt. this may be beating a dead horse, but back when I first took delivery, about a week later I noticed the same noise as mentioned throughout this thread, but since it was barely noticable, I just kind of tuned it out. last week i threw in the nismo clutch and flywheel. Now the noise is back and louder than ever. seems to be around 2000-2500 RPM, mostly under load. I took it to a friend at a Nissan dealership and put it up in the air, and the noise seems to be eminating from the tailhousing of the trans. My guess is the dual mass flywheel masked the noise somewhat. Judging from the responses in this forum this seems to be 'normal', but i have a hard time believing that a transmission with only 10,000 miles on it will have this horrid noise coming from it.
Old May 6, 2006 | 08:13 PM
mistermojorizin's Avatar
When i start the car, i don't hear the noise. After i drive it for a while, then stop and idle, that's when the noise kicks in. (this probably explains why you don't hear it at the dealership but you hear it in the drivethrough). I have noticed that when the noise is happening, if I touch the stick and pull down on it (just gently add a little bit of pressure) the noise gets worse. If i push up on it (again just put my hand on it, and not force it), it makes the noise get quieter.
its cool that this is "normal" and everything while we have the cars new, but is this going to become a problem once the cars get older? i mean, something is hitting something else to make that nasty noise, its gonna give out eventually, probably when the car's out of its warranty period - or if its in the warranty period - the dealer will claim it's wear and tear....
Old Oct 20, 2006 | 01:30 AM
.moO^.'s Avatar
Bringing the thread from the dead. I apologize if it seems as I'm beating on a dead horse.
I recently purchased an used 03' Coupe in great condition except for this sound. Before I made the purchase, the dealer had the service supervisor checked and he insisted that the sound is coming from the input shaft and it's normal. Sometimes the noise would go away but sometimes it doesn't. Based on my reading through couple of the threads, it seems like no one have found a real solution to this issue i presumed?
Old Oct 20, 2006 | 01:49 AM
Otacon132's Avatar
no, theres no fix, and according tot he dealer this is normal. Not exactly sure if the problem persists with aftermarket clutch
Old Oct 20, 2006 | 09:41 AM
Back2VQ's Avatar
not for sure, but my buddy with 03 Z had the same problem (as well as mine), but he changed his tranny/differential fluid with royal purple and the clatter noise went away about 70%. again, not my personal experience but from a very close friend of mine. i have the same problem and it's very annoying.
Old Oct 21, 2006 | 02:09 AM
dwdaewu's Avatar
yea, mine makes those noises too. I just got a JWT flywheel and a Exedy stage 1 clutch. Not only does it makes those noises, its really sensitive to drive now.
Old Oct 23, 2006 | 03:49 AM
DJM AutoWorks's Avatar
its normal and JDMV35 is right when you put after market upgraded stuff in it gets worse....
Old Nov 22, 2006 | 10:03 PM
FLiP22's Avatar
Question Idle Noise?
Im new here on this board. I just recently got a 03 G35. Got a good deal on it. It only has 20K miles on it but at idle I feel a weird vibration and noise every in about 5-7 second intervals? Should I be worried? Its bugs the hell out of me. All you G pros out there...HELP!!!
Thebaws11
Jul 2, 2021 11:36 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
vamarris
Sep 26, 2015 12:56 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Jnm07
Sep 5, 2015 01:16 AM
