Noise Only When It Is Cold
Old Dec 13, 2005 | 01:12 PM
urabus's Avatar
Originally Posted by 6MTzer
Sorry, it's on that other G35 forum.
Totally useless. You would be better off remaining quiet.
Old Dec 13, 2005 | 01:26 PM
ykG35c's Avatar
whining...
i believe i have (or had) the same annoying noise...
when the temps cold and the first start of the day, there would be a whining/squealing noise coming from the engine bay area for the first few minutes of the drive...after the car was warmed up the noise would go away...
first noticed it last year, but didn't think much of it...as the temps got colder again this year, the whiny sound came back and had them check it out when i went in (for other unrelated service)...
on the write up, the resolution/fix was "replaced the eng. drive belts"...specifically lists the fan&alternator belt and the compressor belt...
i'd say the sound is about 99% gone now...on occasion, i think i hear it for a second or two, but it's probably more paranoia than anything (since i'm getting real close to the 60k warranty expiration)...
hope this helps...let me know if you need the parts numbers they listed or anything...
Old Dec 13, 2005 | 01:36 PM
mmpotash's Avatar
Noise
To YKG35c,
No, different noise, different problem.
Old Dec 17, 2005 | 09:39 PM
Brewin98's Avatar
Thanks YKG35c. That's the noise that I have. It started about a month ago when temps. started dropping.
Old Dec 17, 2005 | 10:54 PM
6MTzer's Avatar
Why is that? He knew what I was talking about and we exchanged several PM's about the topic.
Seems to me yours is the "Useless" post.
Old Dec 19, 2005 | 11:18 PM
DTrejo's Avatar
During the summer I dynomatted my car. After I took the rear seats off, I didn't have time to dynomatt so I left them off for a few days. During that time, I would hear something you would describe as an air leak coming from the back seats, but it was loud enough where you could definately hear it. You may want to try taking off the back seats and see if the sound gets louder. It only takes about 20 minutes to take the back seats off. There is only 2 bolts you have to take off.
Old Dec 20, 2005 | 08:23 AM
FAST1's Avatar
Originally Posted by RacerB355
yeah i have had that same exact sound....it only happens rarely or when very very very cold and would be difficult to duplicate for the dealership, just have to live with it
I have the identical problem. It sounds like air is passing by the driver's side window. It only lasts for about five minutes nd only when it's very cold. BTW I was driving my son's '95 Mercury Sable last night, you know the poor quality American built car. Anyway the car has over 100K miles on the odometer, and the dam thing doesn't have even a hint of a rattle or squeak. On the other hand, it seems that every week I discover and have to fix another rattle on my G which has all of 3500 miles on the odometer. Very disappointing, even on a modestly priced car.
Old Dec 20, 2005 | 01:50 PM
binar's Avatar
Originally Posted by g35rcr
i had the same sound...the techs changed out the lower weather strips between the door and fender areas...it seems when it gets cold it shrinks alot letting in air...when car drives around and warms up it expands to normal size
Originally Posted by mmpotash
g35rcr
Did that fix the problem?
bump
Old Dec 20, 2005 | 04:15 PM
mmpotash's Avatar
Noise
BINAR,
The dealership ordered the weather strips, so when they are installed I will let everyone know if that solves the problem. So far they replaced the fuel pump, which did not change the noise.
mmpotash
Old Dec 23, 2005 | 08:51 AM
binar's Avatar
BINAR,
mmpotash
Thanks!
I love you guys
Old Dec 25, 2005 | 08:54 AM
Lucino's Avatar
ck out this thread
the drowning sound seems is common among us, not sure if it's a problem.
ck out this thread on My350z.com
http://www.my350z.com/forum/showthread.php?t=154641
no solution has been found to cure the sound
so far in COLD weather I experience the drowning sound and hard time to get into second gear
just found out last nite my car is leaking coolant, that just ruined my Xmas, now I'm up 8am and still thinking about it.
happy holidays to you all.
Old Dec 25, 2005 | 10:21 AM
mmpotash's Avatar
Noise
Looks like the 350Z has it's own set of noise difficulties. Anyway, the parts my dealer ordered has not come iin yet.
Happy Holidays and Thanks to web sites like this for keeping everyone informed!!!
Old Dec 25, 2005 | 10:30 AM
dR6's Avatar
dR6
I have the exact same whistling noise on my '06 also. I keep checking all my windows and sunroof to make sure it is closed! I'm glad I'm not the only one. It does go away after a bit so it's not that big of a deal. It's so hard to localize where the sound is actually coming from though...
Old Jan 5, 2006 | 07:32 PM
mmpotash's Avatar
Noise
Next week, on the 11th, I will be dropping the G35 at the dealership to install new weatherstripping. I'll let everyone know the results.
Old Jan 14, 2006 | 10:44 PM
  #30
mmpotash's Avatar
Well, the new weatherstripping did not fix the problem. I'm out of ideas and my dealership is out of ideas. So, if anyone has any actual proven solution....
