Want lower gears = torque mulitplier down low
Old Aug 25, 2003 | 07:48 PM
2BG's Avatar
2BG
Hi all,
I've done a 3.45 in a BMW, and couldn't believe the difference in the low end torque vs. the stock 3.15 in that car.
Is there aftermarket gears available for our cars? If so, what's the stock gearing set at for a 6MT coupe vs. what's available from after market companies? I think this is a great way to get "safe" butt-o-meter "pull" down low, and hang with cars with more displacement....until getting to higher speeds.
Help, want lower gears - what's available?
Thx,
2BG'd
Old Aug 25, 2003 | 09:20 PM
BobbyD's Avatar
Re: Want lower gears = torque mulitplier down low
Lower gears(numerically higher) will get you in your power band quicker, but will compromise cruising rpms. This was a great mod on my vette with a 6spd with 5th and 6th gears being overdrive. A set of 4.10 gears really woke up the car and could still cruise at under 2000 rpms on the highway.
I don't think the G35 aftermarket has anything available just yet, could be wrong though.
2003 G35 Sedan 6MT
Old Aug 25, 2003 | 10:59 PM
RamboRami's Avatar
G35driver.com Moderator
Final Drive Gear ratios on G35 coupe:
MT 3.54
AT 3.36
G35c 6MT DG/Willow/HyperGround/BorlaExhaust
Old Aug 26, 2003 | 10:12 AM
3point5SE_Auto's Avatar
get lighter wheels. that will increase the off the line torque somewhat. not to the extent that a 3.83 or 4.10 would do but still it would help.
Better Life thru Chemistry
Old Aug 26, 2003 | 12:49 PM
RamboRami's Avatar
lighter wheels wont increase torque...
You are right they will increase acceleration somewhat, but due to less unsprung weight... definitely not to the extent of a 4.10 as you said lol
Old Aug 26, 2003 | 01:31 PM
Hitman's Avatar
You should probably research the different final drive ratios for other Nissan/Infiniti products. You might find a higher (numerically) gear ratio that would swap right in and give you the off-the-line torque that you're after.
Or check the 350Z forums.... those guys would probably be more likely to be considering a ring and pinion swap.
Old Aug 26, 2003 | 01:33 PM
Hitman's Avatar
smcallis,
You won't see a HP or TQ increase by changing gear ratios. But you will see quicker acceleration (especially at lower speeds) and a slower top speed. It's all in the gearing.
Personally, I think the car is geared just about right. Good pull of the line, and still pulls well at higher speeds.
Old Aug 26, 2003 | 01:55 PM
ryoken's Avatar
Right. You can't see an HP increase at a given RPM without a TQ increase as well. It's a strictly mathematical relationship between the two.
HP = (TQ * RPM) / 5252
However, if there's less mass in the wheels it's trying to spin, it takes less power to spin them faster.
Old Aug 26, 2003 | 09:16 PM
2003z's Avatar
the non turbo z32 has the same rear diff, but a 4.xx:1 ratio.
Old Aug 27, 2003 | 12:22 AM
beavisoncrack's Avatar
You might be able to swap with the 350 convertible. They gave it a different rear end to make up for the extra weight. I was thinking about looknig into it, but figured someone else would get around to it eventually.
Old Aug 28, 2003 | 02:55 PM
ok, when you guys with the coupes do this, I will hold on to your viscous LSD differential for you so it doesn't take up your shelf space
Oh wait then I will have to install it to keep it lubricated and clean as my garage has lots of sand in the air. grin
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
yosip1115
Aug 26, 2015 10:46 AM
Mattdi
Aug 23, 2015 11:27 PM
Frostbite91
Aug 20, 2015 07:20 PM
Tonka211
Jul 25, 2015 03:22 AM
