Engine - Complete Motors Complete Motors & Motor Parts; pistons, blocks, cranks, cams etc.
FS: BC 88mm stroker more than 12k invested
Old Jun 11, 2013 | 05:04 PM
e30cabrio's Avatar
Specs are BC 88mm crank, BC rods 96.5 JE 11.0.1 pistons Ported and polished head 5 angle valve job on +1mm Manley valves and Jim Wolf S7 cams.
http://my350z.com/forum/na-builds/51...-na-build.html
All ARP fasteners, Forged girdle, ARK knockoff large oil pan
I have over 12k in this a stock low mile motor commands 3k. Looking for 5k plus actual shipping.
No front cam solenoid
Cylinder 2 was viewed through a scope and appears to have lost a piece of the top. The crank is ok, the rod is ok.
I will have a picture from the scope later.
Old Jun 11, 2013 | 05:42 PM
JaE35's Avatar
Moderator
G35 Sedan
holy crap, glws that is amazing
Old Jun 11, 2013 | 08:26 PM
e30cabrio's Avatar
Old Jun 11, 2013 | 09:39 PM
G35BAW's Avatar
So whats thw deal with it? Missing? Please explain. Thanks
Old Jun 11, 2013 | 09:47 PM
e30cabrio's Avatar
It was using oil and the #2 plug was covered in oil. We opened the oil pan and I took the pictures I posted. The lower bearing has minimal scoring, the crank none. The upper was tightly installed and would not come out.
At a minimum it needs a piston and it's rings. If I were going to deal with it I'd pull the crank and all pistons and be prepared to replace the rings and bearings.
Old Jun 12, 2013 | 09:48 AM
e30cabrio's Avatar
Cyl 2 is the damaged piston.
Plugs:
1-4
3-6
Old Jun 28, 2013 | 08:55 AM
e30cabrio's Avatar
Offers, reasonable part out requests (don't ask for a valve)
Old Jul 17, 2013 | 11:14 PM
Rennyrennren's Avatar
would u part out cams?
Old Jul 18, 2013 | 07:49 AM
e30cabrio's Avatar
No sorry complete heads yes but not disassembling them.
Sale pending on complete longblock.
Old Aug 7, 2013 | 11:38 AM
SkyWay's Avatar
Just curious whats the best price you could do for both complete heads?
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
Hawk196
Sep 10, 2015 10:37 AM
EricF
Aug 28, 2015 08:27 AM
Jiggerjuice
Aug 26, 2015 09:00 AM
