DIY: Clutch Pedal Remedy
Rating: Thread Rating: 2 votes, 4.50 average.
Old Jun 12, 2011 | 05:17 PM
  #181
karma<3's Avatar
Thanks!
I knew it wasn't just me when I first felt this clutch!! Thanks for the DIY! I was able to do my own variation of this mod and it worked great! It definitely helped some so thank you for creating this thread!
Old Sep 19, 2011 | 11:01 PM
  #182
_FrankStarks_'s Avatar
Bringing up an old thread but I did this mod as well as removing the spring (highly recommend removing spring) and it's like a whole new G. I've got an 07 G35 coupe 6mt and both mods have been working great for me.
Old Sep 20, 2011 | 03:51 AM
  #183
rmyc's Avatar
Originally Posted by ErikNYC
It will help when going up hill, because as soon as u start coming up off the clutch pedal then clutch will start grabbing earlier than normal. The clutch will grab and pull the car sooner than later when letting off the clutch pedal. Just do it worth it for everyone... You will love it.
I use to be able to adjust my clutch the same with my older G20, it was a non hydraulic cable clutch setup.
erik should i do this? cuz i cant stand the 6mt.
Old Sep 20, 2011 | 11:01 AM
  #184
I'm not sure if Eric is referring to the spacer mod but if you hate your 6mt look into the spring removal it will help.
Old Sep 21, 2011 | 10:47 PM
  #185
ErikNYC's Avatar
Yup, it worth it. Make sure the double sided tape u buy is industrial strength.
I been looking for this info. Where can I find it? Thanks.
Old Sep 21, 2011 | 10:55 PM
  #186
I can't find the one specific to 06-07 coupes, what do you drive? If it's 06-07 coupe its very simple and I can fill you in on how to...
Old Sep 21, 2011 | 11:14 PM
  #187
ErikNYC's Avatar
Dang. I have an '05 coupe.
Old Sep 21, 2011 | 11:30 PM
  #188
Remove pin that connects pedal to clutch cylinder. Remove three brass nuts holding pedal assembly in place. Unplug wires (cruise control/start sensor). Remove assembly. Decompress spring by ensuring pedal is in down position. Remove spring. Re-install assembly without spring and enjoy. This is how I did it on my 07. Let me know if you do it and how you like your "new" G driving experience. Best mod on the 6mt for sure.
Old Jan 5, 2012 | 07:53 PM
  #189
DaGdriver's Avatar
Thanks this dyi is amazing!
Old Dec 24, 2012 | 05:23 PM
  #190
LxV Socal's Avatar
I just did this to my clutch and it feels A LOT nicer! but one thing....what if the taped plastics fall off while your driving? like lets say in the summer/heat when they don't stick well
Old Dec 24, 2012 | 05:27 PM
  #191
Deepdiver's Avatar
^ I used super glue and the coins. Its been about 5 summers...not one issue.
Old Dec 25, 2012 | 06:03 AM
  #192
LxV Socal's Avatar
hmmmm...
Would you mind pm'ing me how many and what kind of coins you used?
Old Dec 25, 2012 | 03:13 PM
  #193
serges's Avatar
interested in doing mod on my 06!! Is that the same procedure as the 07? looking for pics to see if i can remove my spring quick. everyone tells me to do it!!
Old Dec 26, 2012 | 12:00 AM
  #194
Deepdiver's Avatar
Originally Posted by LxV Socal
hmmmm...
Check out post #25.
Old Apr 7, 2015 | 11:36 PM
  #195
Drifter2090's Avatar
Bringing old thread back, but I just did this DIY and it feels great! I used the home depot gliders but only used 2 layers of tape on the black/white one. I highly recommend it!
EDIT: would not recommend doing it permanently, because when bleeding/flushing clutch fluid you will need to press the clutch all the way in
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
