DIY: Airbox mod - Cool Air Injector (anti-56k)
Rating: Thread Rating: 4 votes, 5.00 average.
Old Jun 30, 2011 | 11:43 PM
  #121
UR2EZ's Avatar
I unfortunately don't have a before sound clip. I do however, have a K&N filter if you're still looking. I'll be updating this DIY again with an additional step to block the large resonator pocket just behind and above the bottom opening, so stay tuned!
Old Jul 1, 2011 | 03:43 AM
  #122
truexh's Avatar
would this mod with for aftermarket K2 front bumper or only for OEM bumper kind of mod...?
Old Jul 1, 2011 | 04:49 AM
  #123
UR2EZ's Avatar
yes it would work for a k2, you just have to attach the flashing(funnel) to the lower grille... i used a couple black zip ties and punched a couple holes in the funnel and fastened it to the grille
Old Jul 1, 2011 | 05:07 AM
  #124
truexh's Avatar
hmm interesting, i probably will do this mod too, so are you going to update the DIY to 2 and 1/2 pipin instead of 1 and 1/4?
Old Jul 1, 2011 | 09:10 AM
  #125
HwyDrftr's Avatar
Originally Posted by theessence136
I just removed the resonators from each box because I'm not really sold on there being any benefit of running it a few inches to the front, and I haven't noticed any difference in sound. Any problem in doing that? Is there any reason why having a tube connected to it would change the sound, as opposed to just leaving it as a hole in the bottom of the box?
I have mine like that, when driving my intake temp is about 5-6 degrees over ambient, the same as it was before I took off the resonator. The air in that area is pressurized and kept cool with the flow through the bumper. When stopped it may heat soak though, in stop and go my intake temps jump up a lot. I have also modded my air box by adding a large velocity stack over the stock one , cutting an opening in the box under the stock opening and removing the stock port and added a new seal further back.
Old Jul 1, 2011 | 05:00 PM
  #126
UR2EZ's Avatar
Not planning to do that simply because the 1 and a quarter inch pipe fits perfectly snug into the resonator hole. If you use bigger piping you will either have to mod the hole to make it bigger or use an adapter which will result in 1 and a quarter inch anyway..
Old Jul 1, 2011 | 05:03 PM
  #127
UR2EZ's Avatar
That being said, if you do decide to up the diameter, please post in this thread and I will include your instructions in the op...
Old Oct 12, 2011 | 02:27 AM
  #128
g35915's Avatar
i done this mod today i used a 21/2 pipe and the flashing had to cut it down 3ins but it feels like theres a difference sounds louder its not completly done yet though lol
Old Dec 21, 2011 | 09:36 PM
  #129
slidewayz25's Avatar
pretty nice little setup id like to see some real data showing how well it works
Old Jan 8, 2012 | 05:09 AM
  #130
6spd_C's Avatar
im interested in doing something like this. ive had a similiar setup but modified my air box to fit a 3" down pipe from a turbo.I had trouble mounting the pipe to the air box i modified due to the weight of the pipe. But ive been running a mazak 5 axis plasma laser at work and have been thinking about making a ram air box all the way across both lower openings on my 03 oem coupe bumper by making perferations in thin sheet metal say about .015" thick and folding the edges to make the angles i need and sealing the perferations with caulk and paint it black. but im worried about hitting puddles in the rain and forcing water onto and through my k&n. mabey the 90 degree bend will prevent such a thing. and i wonder if i should make the whole in the bottom of the air box bigger for better flow? idk but ill find out. ill start drawing it up this monday. ill keep you posted.
Old Mar 15, 2012 | 10:38 PM
  #131
NismoS13vg's Avatar
add this mod with it as well https://g35driver.com/forums/engine-...ir-intake.html both mods together should ensure more cold air to your stock box
Old Mar 17, 2012 | 05:24 PM
  #132
acee's Avatar
Addict
will both of these provide even more air for our engines and give some gains?
Old Mar 17, 2012 | 10:04 PM
  #133
NismoS13vg's Avatar
dumb azzes hot air on the ground during the day yes! did u forget tht at night its alot cooler.this mod helps regardless what people try to talk down on it all this senseless arguing over a simple DIY i put 2 1/2 inch tubing with rubber roof flash and moded my are box to fit the 2 1/2 in piping and it made a big difference just have to re do it with some zip ties to help it stay put. also did the grill air duct mod i just tried these DIY for the fun of it soon ill have a CAI K&N with flex tube with the same idea directing outside air straight to my filter again thanks to the guy who mad this thread for the idea.....
mod and cut your air box to fit 2 1/2 in piping
Old Mar 17, 2012 | 10:06 PM
  #134
NismoS13vg's Avatar
shhi!! talk to the previous threads but goodluck to those trying this mod cool idea
Old Mar 20, 2012 | 12:35 PM
  #135
slim17265's Avatar
waste of time. I did all of that to no avail. THINK the factory has all of the mechanics to test before the mfg... I looked at airbox and found it sufficient but did not like the way the air was routed over the top of radiator...so after drill ing some ten holes in air box and radiator steel support..the result.....nada
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
