DIY: Manual Transmission Fluid/Clutch Fluid change (with pics!)
Old Feb 19, 2010 | 01:49 PM
  #46
Luv2xcelR8's Avatar
Originally Posted by slim17265
yeah. ALL synthetic gear oil is BAD....I have the only one that is any good. In answer to that YOU would be the last one I would buy anything from
I have to agree with rh334 on this one. I have witnessed first hand many people having grinding issues while using redline. I would recommend giving amsoil a try before you put it down. Do some research and see for yourself. Also, why would you put down another member who was trying to help you out? I will be changing all of my fluids today using Amsoil, I am not going to put anything else in my transmission because I want to take care of my car properly.
Old Feb 19, 2010 | 03:22 PM
  #47
slim17265's Avatar
..........jackass?..................
do you call all of your customers that? you see like a lot of people here I have already used your product and had trouble with it like many people here. How to win friends and influencing people is not by calling them jackass.
http://www.amsoil.com/products/gearl...hitePaper.aspx
I found Mobil 1 75-90 to be superior to your product. and a lot cheaper
Old Mar 17, 2010 | 02:48 PM
  #48
Sammo115's Avatar
Man. Doing a manual transmission is so much easier then an automatic...arg.
Old Apr 17, 2010 | 12:21 PM
  #49
COMMANDOE's Avatar
Great diy. Did mine today in about 20 minutes. I only used 2 ramps did not jack the rear up and it was a breaze. I realize level would have been better but I know I didn't under or overfill based on amount pumped in. For the record I used Royal Purple which I bought from a raceshop in PA for about 12.50 quart.
Oh yeah I find great humor in people arguing over the best oil!!!!
Old May 4, 2010 | 09:41 AM
  #50
ConradoR's Avatar
Subscribed. Getting this done in a week. Bumping this up to the top of my subscribed threads so I dont forget
Old May 4, 2010 | 10:44 AM
  #51
COMMANDOE's Avatar
return to OEM man fluid
To follow up my post above. I had immediately had hard shifts between 1st and second gear post fluid change to full synthetic royal purple.(shifting prior to this change was smooth and flawless).
I changed back to OEM 300 miles later and it shifts perfect now. I join the hordes of those who swear by OEM only........
Old Jul 6, 2010 | 01:10 PM
  #52
Neu Era's Avatar
thanks for the Write-Up!
Old Jul 11, 2010 | 09:12 AM
  #53
Khloro's Avatar
Went to Nissan and they wanted 24 bucks per qt
thank Nismo 9 buck per qt
Old Jul 14, 2010 | 12:41 AM
  #54
akdnj88's Avatar
to the OP, which adapter of the Motive Power Bleeder did you use to bleed the clutch? Please let me know. Thank you in advance!
Old Jul 26, 2010 | 03:10 PM
  #55
Khloro's Avatar
Thanks for the write up . I changed transmission oil OEM and Diff AMSOil ..Drives great
I did the manual bleeding on the clutch took like 30 minutes. I noticed my gears went in easier
2006 G35 28540 miles
Old May 24, 2011 | 10:16 PM
  #56
curin323's Avatar
nice write up. ima do this in this weekend. haha i wont spend money into stupid bodyshop anymore lol
Old Jun 26, 2011 | 11:58 PM
  #57
trentor's Avatar
Since many have issues with the Motiv bleeder, here's the best way I've found for flushing the clutch fluid. Take the reservoir cap off and connect one of these to the bleeder valve. Keep the pressure up to 20-25psi and refill the reservoir each time you fill the little pump cup. I think 3 or 4 rounds fully flushed it, but I can't remember exactly.
$20-25 at Harbor Freight
Old Jun 27, 2011 | 12:01 AM
  #58
trentor's Avatar
Also, that vacuum pump is worthless for brake fluid. I could never get it to seal in the bleeder valve well enough to get enough vacuum pressure.
Old Jul 24, 2011 | 06:11 PM
  #59
MurByrne's Avatar
useful info. Going to use this soon to change my clutch fluid
Old Mar 1, 2012 | 01:40 PM
  #60
happycamper's Avatar
Thank for the awesome tutorial! I have a 2005 G35 Sedan Automatic. Would this process be the same for me? I
