DIY: Manual Tranny and Diff Fluid Change
Old Jul 13, 2004 | 12:36 AM
dklau33's Avatar
Even though this is a real easy procedure, we decided to take pics and make a How To anyway. This past weekend myself, Vinh (drsifu), and Ty (Sagi) did a fluid change on our manual trannies and rear diffs. Easy, fun, and a little messy. I'd strongly suggest wearing your "work" clothes and lining the areas your going to work with with newspaper to make an easy clean up.
Tools Needed:
Ratchet
10mm Hex Bit Drive
Pan or Container to catch used oil
Gear Oil Pump
Torque Wrench
Car Jack
Jack Stands
Fluids Needed:
3.25 qts of Genuine NISSAN Manual Transmission Fluid
(MTF) HQ Multi 75W-85 or API GL-4, Viscosity
SAE 75W-85 or 75W-90
1.5 qts API GL-5*1, Viscosity SAE 80 W-90
Old Jul 13, 2004 | 12:38 AM
dklau33's Avatar
Re: DIY: Manual Tranny and Diff Fluid Change
1. Get your car up on jackstands or ramps on all 4 corners. Safety first! Here's Ty getting the front end up.
Old Jul 13, 2004 | 12:39 AM
dklau33's Avatar
Here's Vinh getting his "Jack On".
Old Jul 13, 2004 | 12:40 AM
dklau33's Avatar
Here's the beauty up on all 4 corners.
Old Jul 13, 2004 | 12:43 AM
dklau33's Avatar
2. Locate the tranny case under the car in between the two cats. Find the filler plug on the passenger side of the tranny case and open it with the ratchet and 10mm hex bit drive. Clean the plug if necessary.
Old Jul 13, 2004 | 12:44 AM
dklau33's Avatar
3. Find the drain plug on the bottom of the tranny case and open with the ratchet and hex bit drive. Drain oil into pan or container. Do this only after you have allowed enough time for the car and fluid to cool down so you don't burn yourself.
Old Jul 13, 2004 | 12:50 AM
dklau33's Avatar
4. Clean the drain plug if necessary. You'll probably have a little bit of paste which is normal from metal shavings of wear and tear. After the oil has drained out replace the drain plug and torque down to 25 lbs using the torque wrench.
5. Pump in the new oil through the filler plug using the gear oil pump. You should put in 3.25 quarts or close to that. The amount of oil should just come up to the level of the bottom of the filler plug hole. If you put too much just let the excess drip out until it stops dripping. Once you are finished replace the filler plug and torque down to 25 lbs.
Old Jul 13, 2004 | 12:53 AM
dklau33's Avatar
6. Repeat the same basic procedure on the rear differential. Undo the filler plug on the passenger side of the diff. Then undo the drain plug on the bottom, back of the diff. Drain oil into an oil pan or container.
Old Jul 13, 2004 | 12:55 AM
dklau33's Avatar
Notice how the diff drain plug has alot bigger magnet than the tranny drain plug does.
Old Jul 13, 2004 | 12:58 AM
dklau33's Avatar
7. After all the diff oil has drained replace the drain plug and torque down to 25 ft-lbs. Put in new oil using the gear oil pump. Replace the filler plug and torque down to 25 ft-lbs.
That's generally all there is to it. Pretty easy. After your finished give yourself a pat on the back and go grab a cold one for a job well done.<P ID="edit"><FONT class="small"><EM>Edited by RamboRami on 07/14/04 01:10 PM.</EM></FONT></P>
Old Jul 13, 2004 | 01:32 AM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
Thanks for the DIY instructions. I just changed out my clutch for the Nismo one had the tranny fluid replaced with Synthetic, Now I gotta do the Rear diff. Thanks once again for the Pics.......
Better Living Through Chemistry, N20
CPV35 Driven BY David K, VQ35DEN Tuned By DR CHARLES
...........NismoCPV-35
Old Jul 13, 2004 | 02:03 AM
metasystem's Avatar
04 G35 Coupe 6MT Gold Brembo’s
Thanks for the pics guys.
Me and another G on this forum (with a GReddy TT) both just finished replacing our stock clutches with the Exedy carbon (+ flywheel) at a shop here in Toronto. I'll post pics soon.
I'm also replacing the tranny fluid with synthetic, probably tomorrow...
Thanks again!
Old Jul 13, 2004 | 03:08 AM
Premier's Avatar
Great writeup guys. Looks like everyone had fun doing this..........maybe I'll swing by next time!
Certified Window Tint & Detailing Specialist
3M / VentureShield Paint Protection Film Dealer
Madico Window Film Dealer
syu@machiii.net
2003 AT Sedan / 2004 6MT Coupe
Old Jul 13, 2004 | 05:50 AM
neffster's Avatar
You keep saying "torque down to 25 lbs".
Do you mean 25 ft-lbs or 25 in lbs? Force is measured in "lbs" (Force) and torque is measured in "ft-lbs" (distance x Force).
Thanks for making the clarification and the GREAT WRITE UP! I think I'm going to do my own 7500 mile oil, tranny and diffy change thanks to this wonderful write up.
Here's to hoping that my color printer will print these photos out in detail instead of a big black rectangular blob... [img]/w3timages/icons/crazy.gif[/img]
<font color=blue>The above statements are only my take on the issue. If you disagree with anything I typed then you are 100% right!</font color=blue>
