RevUp Intake question.....
Old Aug 31, 2006 | 10:11 PM
rlwjr1's Avatar
Question RevUp Intake question.....
Just for my own edification, does anyone have any pictures of the inner workings of a RevUp intake PRIOR to a MREV2 install??? In other words a stock intake.
Old Aug 31, 2006 | 11:37 PM
NJlakeshoreG's Avatar
do u mean if someone ported it out? or jsut what a stock intake looks like??
Old Sep 1, 2006 | 01:14 PM
rlwjr1's Avatar
Question
If a MREV2 is just a NON-REVUP intake ported for the REVUP, what do the guts of a stock REVUP intake look like????
Old Sep 3, 2006 | 02:11 AM
Shavel's Avatar
MREV 2 is the non-revup lower plenum but supposedly heavily ported (but I have not seen one so I can't tell you for sure). I do know that the stock revup plenum has shorter runners then the nonrevup plenum. I have one of both. I'm hoping to do some porting on the nonrevup and installing it in my '05. There should be some gains, just not sure how much.
Old Sep 4, 2006 | 10:55 PM
rlwjr1's Avatar
Never mind...
Old Sep 5, 2006 | 08:52 PM
reelfreak's Avatar
I just installed it, here is my stock one vs the Mrev2
Old Sep 5, 2006 | 09:57 PM
rlwjr1's Avatar
Thank you, that is just what I needed!!!
Old Sep 5, 2006 | 10:15 PM
vt_maverick's Avatar
So for the less mechanically-inclined folks in the room, what exactly are the differences that I'm supposed to see between the two? Yeah, I can see slight visual differences and I've read the material on the forums and Motordyne's website, but can someone translate all that into something along the lines of "see that third bump on the left, it makes you go faster."
Old Sep 5, 2006 | 10:40 PM
rlwjr1's Avatar
The '06 intake has a larger plenum with shorter runners. This will promote high RPM breathing/HP
The '03/'04/MREV intake has longer runners with a smaller plenum. This will promote lower rpm torque over HP.
I just wanted to see what the inside looked like compared to a Non-RevUp
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
vamarris
Sep 26, 2015 12:56 PM
