SES - Help!
Old Sep 7, 2006 | 08:00 PM
UFGatorG35's Avatar
SES - Help!
I was driving last night and my SES light came on - steady on not blinking. The gas cap is on tight, all the seals around the intake/hose are tight, and it looks like the oil is fine.
I just tried to reset the ECU using these instructions.
After a couple tries the SES light turned off, but when the engine revs between 3 and 4k rpms it starts to flicker. When I released the pedal and let it idle it stayed off for the most part but still flickered here and there. By flicker I mean not a steady blink, but a sporadic on/off a random number of times then stays off again.
Any ideas?
Old Sep 7, 2006 | 08:01 PM
Jeff92se's Avatar
Red Card Crew
If you don't have an OBDII scanner, take it to a parts store so they can run the code.
Old Sep 7, 2006 | 08:04 PM
2006_G_coupe's Avatar
+1 ^
Old Sep 8, 2006 | 11:36 AM
UFGatorG35's Avatar
Going to go find a scanner, would someone be so kind as to tell me where I find the hook up in the car. Im almost embarrassed to ask...
Old Sep 8, 2006 | 11:43 AM
Jeff92se's Avatar
Red Card Crew
Haha! Just left of the steering wheel, under the dash. Noob!
Old Sep 8, 2006 | 11:55 AM
UFGatorG35's Avatar
Thank you!
And yeah, with as many mods and installs as Ive done I have never messed with the ODB port.
Old Mar 30, 2014 | 10:43 PM
keithk831's Avatar
Bringing this back from the dead. I just had this same thing happen to me tonight...any ideas?
Old Mar 30, 2014 | 11:08 PM
Urbanengineer's Avatar
Did you get your code read?
Old Mar 30, 2014 | 11:09 PM
keithk831's Avatar
No, it just happened about an hour ago and all the shops are closed (like Autozone).
Old Mar 30, 2014 | 11:10 PM
keithk831's Avatar
More info: I came back home and turned off the car, then turned it back on and went for another drive and it didn't happen again. Didn't notice a loss of power in either instance.
Mry
Mar 3, 2023 01:03 AM
Vqalexisz
Oct 14, 2015 12:48 AM
vamarris
Sep 26, 2015 12:56 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
