a/c compressor pulley removal
Old Oct 19, 2003 | 03:44 PM
theskipps's Avatar
Does anyone know how the a/c pulley is removed from the compressor.I ordered a new one,because mine got bent.When i received it, the pulley and the shaft were made togeher ,and i need to remove the old one from the compressor.
Thanks
Old Oct 19, 2003 | 04:22 PM
Msedanman's Avatar
O.F. Administrator
Re: a/c compressor pulley removal
According to my ESM, after the surpentine is removed, the centre bolt comes out first, then a puller is used to remove the clutch assembly.
Unless you've got the right tools it looks like a job for the shop, who will likely remove the compressor first due to lack of space.
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Oct 19, 2003 | 05:00 PM
theskipps's Avatar
Hey GSM,
I appreciate that information ,but after reading again what i wrote, i don't believe the way i put it is very clear.The problem is the belt pulley is pressed on to the shaft that slides inside the compressor .What i'm trying to find out is how to remove the shaft from the compressor.There isn't a center bolt to remove .Could you look again and see if there's a way to pull this shaft ,or you might have to go into the compressior itself to take it out.The new shaft looks as though it has a lock ring on the end of it ,and all you would have to do if you could remove the old one is just push it in ,and it would lock .Anyway i appreciate you taking a look.
Thanks
Old Oct 19, 2003 | 05:01 PM
theskipps's Avatar
pulley removal
Hey GSM,
Thanks
Old Oct 19, 2003 | 06:55 PM
Msedanman's Avatar
O.F. Administrator
Re: pulley removal
Hey bro, I've copied all 3 pages from the ESM concerning the dismantling of the shaft: Page 1/
Old Oct 19, 2003 | 06:56 PM
Msedanman's Avatar
O.F. Administrator
Re: pulley removal
Page 2/
Old Oct 19, 2003 | 06:57 PM
Msedanman's Avatar
O.F. Administrator
Re: pulley removal
and Page 3/
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
