View Poll Results: Year/Model of your G having EXCESSIVE OIL CONSUMPTION
2003 5AT
68
9.51%
2003 6MT
76
10.63%
2004 5AT
48
6.71%
2004 6MT
83
11.61%
2005 5AT
55
7.69%
2005 6MT
172
24.06%
2006 5AT
24
3.36%
2006 6MT
150
20.98%
2007 5AT
13
1.82%
2007 6MT
26
3.64%
Voters: 715. You may not vote on this poll
Poll: Oil Consumption
Old Aug 3, 2008 | 10:24 AM
  #151
V35 Skyline GT's Avatar
6MT Coupe
My oil light never came on with my old VQ b/c I never let it go much below a qt down. Oil light is not a good way to tell you need to add oil
Old Aug 3, 2008 | 10:30 AM
  #152
OCG35's Avatar
the light only tells you if you do not have oil pressure... it doesnt tell you if you need oil.
Old Aug 3, 2008 | 10:34 AM
  #153
6MT Coupe
Originally Posted by R1jamn
My 2007 6mt coupe has 3246 miles on the clock. I just checked my oil and it is 9mm low on the dipstick. According to the TSB chart I am well with in the "OK" range.
When I do my first oil change at 3750 miles my G will have used approx 1/2 qt of oil. Still this is well within the range of "OK".
Now granted my engine is still new and perhaps I consumed oil while the rings were seating themselfs in. But when I do go to Infiniti for my first oil change I will have them record it and have it on file for future reference.
I broke the engine in according to the owners manual and in my experience I used more oil than what I believe is acceptable. On the optimistic side, I don't have the pinging problems that other G owners are having, but summer is still just around the corner.
They may have changed the engine at the end of the production run for 2007to the V2 version. The TSB states that 2005 -2007 G35 6mt Coupes built before May 29, 2007 may be affected by this Oil consumption problem.
That was my exact thought when I first saw the TSB, being that's when the those V2's first became available for OC warranty replacements (May/June 07). Prior to TSB and that cut-off production date on 07's, they were using a different long block replacement part number that ended in M1 not M9 like now.
Old Aug 3, 2008 | 10:37 AM
  #154
6MT Coupe
When you loose oil pressure, you've lost suction on the pump pick-up which means hardly any oil in engine.
Old Aug 3, 2008 | 10:41 AM
  #155
OCG35's Avatar
Not always true… I had a 280Z that lost oil pressure… the valve that allows one-way flow from the filter failed and there was no pressure…. The light was on, but before I could get off the fwy and pull over all the oil blew past the seal on the filter and the motor seized…
Anyway – the light is not an indicator of low oil. Low oil could be a result of not having oil pressure though.
Old Aug 3, 2008 | 12:44 PM
  #156
6MT Coupe
Agree, your example though rare occurrence, can happen. Unfortunately with these rev-up VQ's, it's due to critically low oil 99.9% of the time. That's been proven here on all the OC threads as well as 350Z's OC thread, except they have an actual pressure gauge and not what I call an 'idiot light' on ours.
Old Aug 3, 2008 | 02:16 PM
  #157
OCG35's Avatar
by the time the light comes on (because of no oil), its probably too late... using the light as an indicator for low oil is not a wise idea... check the actual fluid level periodically.
Old Aug 3, 2008 | 03:37 PM
  #158
6MT Coupe
Yup already knew that, thanx.
Originally Posted by soosexyg35
my oil light comes on religously every 997 miles...add another quart of mobile 1...996-997 miles later my fav light comes back on...POS...it seems that the MT are primarily experiencing the problem. Infiniti really needs to get their $hit together
Originally Posted by manbeer
damn, my oil light only comes down when i am 4 or more quarts low
No harm, no foul, no worries
Old Aug 4, 2008 | 10:38 PM
  #159
soosexyg35's Avatar
i used to check the fluid level all the time..it was always low...I guess I just got sick of it..and the run around from infiniti...so, if the light comes on, it goes off by adding oil and saves me the trouble of checking it. I solved the problem by just getting rid of the car all together.
Old Aug 5, 2008 | 01:50 AM
  #160
manbeer's Avatar
going to the dealer to get the 1000 miles check for consumption tomorrow and i took another peek. it's already past the L down at the bottom 1/4 inch or so on the dipstick
Old Aug 5, 2008 | 04:19 PM
  #161
OMG35S's Avatar
Sorry to hear about your oil consumption issue. What dealer are you going to for the OC test? I'm located in New York too. Keep us updated. Thanks
Old Aug 6, 2008 | 09:06 PM
  #162
manbeer's Avatar
Went to the dealer yesterday w/ 1100 miles on the car since the last oil change.
I had checked the level again prior to drivng up there. when i got there the tech checked (i knew for a fact that it was barely touching the dipstick) and just laughed and told the SA, yup, if it's def. MORE then a quart. Replacement is ordered. I went ahead and ordered a JWT clutch/flywheel combo cause i figured they are gonna stick me with a new OE clutch and flywheel for over 2 grand at the last minute like they often do under these circumstances.
I'm just praying that everything goes together as smoothly as possible and they don't **** anything up, and last but not least that my 2nd engine doesn't consume oil.
drive4fun, where in NY are you
Old Aug 6, 2008 | 10:59 PM
  #163
OMG35S's Avatar
It seems like the dealer didn't give you much trouble. You will most likely consume oil with the v2 until you reach 5-10k miles. Just the normal break-in procedure. Good luck with the new engine. I'm in the Queens area. What dealer are you getting the swap done at?
Old Aug 6, 2008 | 11:53 PM
  #164
6MT Coupe
Make sure they have certif master mechs. Less chance of any V2 swap screw-ups.
I gave mine my lug socket and lug key both taped so no damage to inside of my wheel lug holes. Ask them hand ratchet only and no impact please. No wheel damage when my G returned.
Old Aug 22, 2008 | 06:50 PM
  #165
DVelasquez's Avatar
2004 coupe 6mt new engine @ 30k, it took the stealership 2 months for the swap and letters from the BBB to do it.
