View Poll Results: Year/Model of your G having EXCESSIVE OIL CONSUMPTION
2003 5AT
68
9.51%
2003 6MT
76
10.63%
2004 5AT
48
6.71%
2004 6MT
83
11.61%
2005 5AT
55
7.69%
2005 6MT
172
24.06%
2006 5AT
24
3.36%
2006 6MT
150
20.98%
2007 5AT
13
1.82%
2007 6MT
26
3.64%
Voters: 715. You may not vote on this poll
Poll: Oil Consumption
Old Feb 11, 2008 | 04:40 PM
  #136
OG35Driver's Avatar
No kidding I upgraded my tranny, LSD, & final drive. Mucho Dinero, and it never seems to end. Oh, well. Thanks for all the insight. It is much appreciated. I will give Sam a call. Thanks again...
Old Mar 6, 2008 | 08:50 PM
  #137
MadMonkey's Avatar
Finally after 5 consistent oil consumption tests, they have ordered my VQ.
Does anyone know if I will be receiving a new engine or a rebuild? just curious from those that have gone through this....also any problems after the swap?
thx!
Old Mar 8, 2008 | 04:22 PM
  #138
wied's Avatar
GTM in Riverside County - Contact Info?
Originally Posted by V35 Skyline GT
^Depends on what grade internals, head work, etc. And in all honesty I don't know what my friend paid. He never told me the exact amount.
Plus he had his tranny built to handle the high hp/tq at the same time. Know it wasn't cheap.
If you like or know about Sam at GTM. I'd suggest giving them a call and probably get a ballpark figure.
Have heard many good things about that shop. Think they're in Riverside County.
There's many options when it comes to rebuilding which changes the cost a lot.
Anyone have contact info for Sam at GTM?? Muchos Gracias
Old Mar 8, 2008 | 04:48 PM
  #139
Andy2434's Avatar
PM Sam at SAM@GTM.
Old Mar 9, 2008 | 04:35 PM
  #140
OCG35's Avatar
909-481-1601
Old Mar 12, 2008 | 02:24 AM
  #141
V35 Skyline GT's Avatar
6MT Coupe
In case no one knew, Infiniti has revised their TSB on the OC issue.
Same revision with 350Z's. Both on 2-27-08.
They have eliminated the 0-500 and 501-1000 mile 'no good' columns.
The remaining chart is the same as the original TSB.
Attachment 85081
Old Apr 18, 2008 | 01:42 AM
  #142
hydramada's Avatar
Just got my car back from the stealership with a new VQ installed. Had them put a new clutch in while it was apart and just paid for parts..
Old Apr 20, 2008 | 09:46 AM
  #143
CatsTasteGood's Avatar
I also just got a new engine. Picked it up less than a week ago. On the way home the SES came on - O2 sensor and camshaft position actuator. I called the dealer on the way home. He told me to clear out the codes and see if they come back. They did the next day, so now I have to take the car back tomorrow. The biggest pain in the *** about this is the closest dealer is 1.25 hours away.
Old Apr 22, 2008 | 06:22 PM
  #144
alagos's Avatar
Well, after taking my car to the dealership because of unsual noises and the check engine light coming on. I was told that my car had almost no oil!!! This coming after the fact that I had changed my oil just 3K miles ago.
Needless to say, I'v started my oil consumption testing and based on what's happened already will probably getting a new engine as well
Old May 22, 2008 | 11:40 AM
  #145
OMG35S's Avatar
How many 2007's are not having this issue? The poll only shows 3 G35's 6mt with oil consumption issues. How many are not experiencing this problem? Did they change any aspect of the engine for the 07's from the 05-06?
Old May 22, 2008 | 06:23 PM
  #146
R1jamn's Avatar
My 2007 6mt coupe has 3246 miles on the clock. I just checked my oil and it is 9mm low on the dipstick. According to the TSB chart I am well with in the "OK" range.
When I do my first oil change at 3750 miles my G will have used approx 1/2 qt of oil. Still this is well within the range of "OK".
Now granted my engine is still new and perhaps I consumed oil while the rings were seating themselfs in. But when I do go to Infiniti for my first oil change I will have them record it and have it on file for future reference.
I broke the engine in according to the owners manual and in my experience I used more oil than what I believe is acceptable. On the optimistic side, I don't have the pinging problems that other G owners are having, but summer is still just around the corner.
They may have changed the engine at the end of the production run for 2007to the V2 version. The TSB states that 2005 -2007 G35 6mt Coupes built before May 29, 2007 may be affected by this Oil consumption problem.
Old Aug 2, 2008 | 06:35 PM
  #147
manbeer's Avatar
at 600 miles on an oil change my car is now reading 15mm low on the dipstick, 3/4 of the way down to the L. Thats pretty bad, no? I am scheduled to go back next week for the first 1,000 mile oil reading on the consumption test so we will see what happens
Old Aug 2, 2008 | 08:09 PM
  #148
OMG35S's Avatar
According to the TSB you should receive a new engine. If you lose more than 8mm by 1,000 miles you are considered in the No Good area.
Old Aug 2, 2008 | 08:57 PM
  #149
soosexyg35's Avatar
my oil light comes on religously every 997 miles...add another quart of mobile 1...996-997 miles later my fav light comes back on...POS...it seems that the MT are primarily experiencing the problem. Infiniti really needs to get their $hit together
Old Aug 2, 2008 | 09:34 PM
  #150
manbeer's Avatar
damn, my oil light only comes down when i am 4 or more quarts low
