Humming Sound at Idle
Guys... I picked up my 05 G35 Sedan 3 weeks ago.... im noticing that there is a humming sound that comes at idle. It will be there for 2-3 seconds and then disappear.... but will come back in cycles. Is it Normal for this engine??? I just had the oil changed and was hoping it will go away but its still there.
I also hear a hydraulic release sound when i first start driving in the morning.... no matter if the AC is on or off. Any idea what thats from??
If I take it to the dealer.... are there any issues that I should address with them???
Thanks.
Thanks.
Thanks.
Thanks.
The other sound you hear when you first drive away is the ABS self test. It's a soft "sproiiiiiinnng" sound when you first reach 3 or 4 mph, completely normal.
sounds like you are hearing the electric fuel pump.yours might just be a little noisier then most.the fuel pump is under the pass side rear seat,while the car is running put your ear on the seat and see if the noise is from that area.
I will check for the fuel pump.... but its more like the ABS sound
usual_suspect... if its the ABS... I will have to live with it.... but that will suck big time.... cuz that irritates the heck outta me.
If it's loud enough to "suck", it must be something else.
Thanks.
Thanks.
Can you tell where the humming is coming from? like the front or the back of the car? Ive been getting a buzz when my car warms up
Thanks.
Thanks.
I also have this problem. '04 G35 C APS TT. The sound I hear is after the car has been sitting and is cool. It sounds like a tea kettle slowly building pressure occuring between 2k-3.5k rpm in any gear. If you put your foot into the clutch the sound drops out. I have had it into the dealer on several occasions, even leaving it with the service manager to drive home, and they have not figured out what it is. Not the fuel pump. Does you 'humming' occur under similar condidtions?
Buzzing Sound #$$#@
Thanks.
Thanks.
The buzzing sound for me comes from the belts or the pulleys the belts are on. Almost sounds electrical, that was the first thought i had when i heard it. Checked the engine and found the sound coming from the belts.
-Austin B
My 05 sedan had sort of a buzzing/whirring sound that it would make on initial start up towards the right front of the engine that turned out to be the alternator belt idler pulley(I was afraid it was the camchain tensioner). Replaced it and the a/c idler for good measure, problem solved. O'Reilly's had them in Gates.
