SES light comes on a day after testpipe install
Old Oct 24, 2006 | 11:04 PM
46.5quartermile's Avatar
SES light comes on a day after testpipe install even after o2 non foulers
I installed test pipes last night and today the SES light came on. Is this just a coincidence or is it because of the test pipes?
Old Oct 24, 2006 | 11:14 PM
abcquackyxyz's Avatar
its test pipes..you gotta get non foulers..o2 sensors.
Old Oct 25, 2006 | 12:27 AM
Where do I get those and do I have to install them on every o2 sensor behind the cat?
Old Oct 25, 2006 | 02:18 AM
Calvin's Avatar
Overglorified Altima
you can get them from pepboys, kragen, or any local autopart store
'foulers are used to space the O2 sensors out from the exhaust stream so they don't sniff so much - then the errors wont occurr. without cats, more gases flow, as they aren't burned, and the O2 sensors will sens that and throw a code. if you space them back, and not let them breath it all in, you fool them.'
Old Oct 25, 2006 | 10:28 AM
trey.hutcheson's Avatar
What you need are spark plug non-foulers/spacers. Like mentioned above, they are available at most autoparts places, and they're pretty cheap. They come in pairs; you will need two pairs.
You will drill out the tip of one(about 1/2" diameter), then screw it into the opening of another. The o2 sensor will then screw into the non-fouler. And yes, you'll need to do twice; once for each o2 sensor in the test pipes.
I probably didn't explain it very well. Instructions, with pictures, are available here.
If you don't feel like doing it yourself, there was a guy on my350z that was selling them pre-drilled. His thread is here.
Old Oct 30, 2006 | 03:54 AM
I made and installed the o2 non foulers and the ses light still comes on. WTF!!!!!!!!!!!!!!!
Old Oct 31, 2006 | 05:11 PM
Omeezy's Avatar
you must not have done it correctly. did you use two spacers on each side? Did you correctly and tightly screw them in? Did you put the spacer on the rear O2 sensors and not the front? I ask all of these because there is no reason yours should not work. I did it on my 05 coupe and it works just fine.
Old Oct 31, 2006 | 05:18 PM
I don't doubt his claims. There have been a few z's lately claiming the same on my350z.com. I don't have a solution, or even a hint of one, to offer; that's the only reason I haven't responded yet.
And I don't think he would have put them on the forward sensors. Those are mounted in the stock manifolds. Plus, who knows what would have happened had he spaced out those front sensors; those are the sensors that the ecu monitors to control A/F.
Old Oct 31, 2006 | 09:38 PM
ballisticus's Avatar
OK. I'll assume you didn't reset the ECU because I don't see anywhere that you said you did. Once the SES light comes on, you have to turn it off by resetting the ECU.
The no-foulers just prevent it from coming on again after you've done the reset.
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
joel extreme
SOCAL Meetings & Events
Jul 23, 2015 04:13 AM
