5AT Dyno Pulls
Old Dec 17, 2006 | 07:45 PM
bluestacy04's Avatar
5AT Dyno Pulls
I've been reading on my350z.com that a lot of people do their dyno pulls in 5th gear. I did mine in 4th. Its something about a 1:1 ratio. any one know of a difference?
Andrew
Old Dec 18, 2006 | 02:12 PM
MarkSGP's Avatar
Andrew, It really depends on what dyno you are using
Andrew
On the Dynapack, you have to set the Gear Ratio for whatever gear you are pulling in & that ends up being the adjustment for the 1:1 so that the RPM reads correct. On the Dynojet, they use a RPM Pickup for that but, recommend to pull in a 1:1 ratio for the readings... 4th gear on the 5AT is the 1:1 though, so you are fine.
Mark
Old Dec 18, 2006 | 03:52 PM
MarkSGP's Avatar
I am trying, just so busy. You know how it is over here but,-->>>
Originally Posted by HomieG35
Mark! Glad to see your making your way over!
We have a whole new support team here now & January will hold some suprises to advance everyone.... Thank You for the support!!
Mark@SGPRacing
Old Dec 21, 2006 | 05:07 PM
VQguy's Avatar
Mark
Yes, what he said
Old Dec 21, 2006 | 05:10 PM
Jeff92se's Avatar
Red Card Crew
I know you can select 4 so it won't go into 5th. But how do you go WOT and prevent it from downshifting into 3rd?
Old Dec 21, 2006 | 08:38 PM
Earl's Avatar
Question. How do you get a 1:1 gear ratio (crankshaft torque plate to A/T output shaft) with a TC (torque converter) in the middle?
As many have proven to ourselves on mutiple A/T G35s and 350Zs, dynoing them in third "gear" gets the most consistent results.
We've found that early cars won't hold in 3rd "gear" unless the RPMs are above 3600-3800 and if it downshifts on the dyno's rollers you're basically done for the day, or at least for a while due to high A/T fluid temperature. Less A/T fluid viscosity - less TC energy transfer. (That's why your shifts are "stronger" on cold days.)
Why not forth "gear"? Read your factory service manual. Hint: Pay attention to the the 4th "gear" partial TC lock-up info. There is one exception to 3rd "gear". If you elect to find the wires that lock up the torque converter in forth and provide them with a proper signal then you'll have the forth gear 1:1 gear ratio you seek. We haven't aren't inclinded to do so.
Old Dec 21, 2006 | 09:06 PM
booger's Avatar
I dyno on a Mustang dyno . And we always use 3rd with my AT5 . We have tried 4th and the results never very more than 2 whp either way .
Old Dec 22, 2006 | 05:54 PM
was 3rd the higher hp?
Old Dec 23, 2006 | 10:14 AM
Earl's Avatar
2 to 7 peak HP advantage to 3rd "gear" is what we've seen. Our charts show it's over the whole range.
Old Dec 27, 2006 | 12:39 PM
Q45tech's Avatar
Mechanical engineering tells you that for every gear mesh or/and gear direction change the frictional losses increase by 1%.
Usually 2% differences in any non direct gear even 5th/6th.
Don't confuse the tire frictional changes with speed of interface [tire to roller] or the tire diameter gain which changes under higher speed [greater than 100 mph].
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
Learned Hand
Oct 1, 2015 09:02 AM
