Ecm
Old Jan 29, 2007 | 04:48 PM
pmav's Avatar
Ecm
Anyone know if I could put a 2004 ECM in an 2005 G35 2 door coupe.
Or even a 2005 g35 4 door if that would fit
Mine has issues and it is the only one I could find.
Both are automatic cars!
Old Jan 29, 2007 | 06:49 PM
ballisticus's Avatar
Should work. Plug it in and try. If not, you can always re-sell it on Ebay etc.
Old Jan 29, 2007 | 06:59 PM
Jeff92se's Avatar
Red Card Crew
I don't think it would work. Not because it's a coupe/sedan thing. Although I think there might be differences. But because of the key transponder. When you plug in the new ecu and then plug in your key, the ecu's security won't reconize your key transponder signal. No workie. You might have to get your key reprogrammed at the dealer. That is if your ecu's are actually swappable.
Old Jan 29, 2007 | 07:06 PM
ttrank's Avatar
Grocery getter
I don't think it would work. If you can try before you buy.
Danielek
May 1, 2022 01:28 PM
Danielek
Oct 7, 2015 09:59 AM
yosip1115
16
Sep 28, 2015 04:14 PM
vamarris
Sep 26, 2015 12:56 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
