Mobil 1 Oil users
Old Mar 6, 2007 | 12:41 PM
  #76
driftGT350's Avatar
Originally Posted by rob40wilson03
im pretty sure thats not a german phrase, haha
ahahah I know I just felt like saying that
Old Mar 6, 2007 | 02:02 PM
  #77
abcquackyxyz's Avatar
Originally Posted by driftGT350
time to say bye bye the m1 and ello govenor to gc...
sorry to ask again, i read the is it too thin quote etc... but
in socal running the gc 0-30 is okay right? i like to be reassured. thanks.
totally fine i am using it right now.
Old Mar 6, 2007 | 04:19 PM
  #78
redlude97's Avatar
Originally Posted by Nismo G
I was actually at 3200K miles on my trip so it was time for an oil change. I have used mobil 1 for the last 30K miles or so i would say and last night i went to pepboys and picked up 5 quarts of royal purple 5w-30. I then realized that i needed a power steering change since we havnt had one since i think 30K miles (now have 85K). So i called my nissan mechanic, i can take my car there and he does a little under the table work on my car (cost me $30 for full powersteering flush, condition, and refill). Anyways, i told him i was using royal purple this time and forgot to buy a mobil 1 filter so he gave me a OEM nissan filter, which actually looks the same as the mobil 1. We lifted the car on the lift drained the oil and replaced the filter and the oil. After i left $40.00 later the car is running SOOOOO much smooth than with the mobil 1.
-sean
An OEM filter looks nothing like an m1 filter once you take it apart, they are similar in construction to Frams
Old Mar 6, 2007 | 05:01 PM
  #79
ttrank's Avatar
Grocery getter
Is 0W30 thick enough for boosted cars?
Old Mar 6, 2007 | 05:03 PM
  #80
Jeff92se's Avatar
Red Card Crew
You plan on running it hard when cold?
Old Mar 6, 2007 | 05:22 PM
  #81
Nismo G's Avatar
tru, the materials are different. I was refering to the little valve that sits inside the filter to hold the oil up in the engine...didnt specify that. Sorry
-sean
Old Mar 6, 2007 | 09:04 PM
  #82
soxx35's Avatar
If you noticed all your readings progressively had lower readings. So your engine was just getting broken in as the mileage increased. You started with mobil 1 so i would run mobile run for a few more oil changes and see if you get the same results as the original times you used it. I bet youll get lower readings. If not i stand corrected but to truely make a statment you need to test the mobil 1 again.
Old Mar 7, 2007 | 04:31 PM
  #83
rob40wilson03's Avatar
please keep this thread going..... its a good one, very informative
Old Mar 7, 2007 | 10:56 PM
  #84
Ahujadaddy's Avatar
well once again...has anyone tried to use the greddy racing oil?
-sean
I got a friend with a SC'ed Scion tC. He's sponsored by ptuning and uses that GReddy oil... it's actually BLUE! LOL Most importantly though... it is a Group IV oil
Here's a link:
GReddy 5w-30
I never used it myself, and my friend never did a UOA on it. So i dunno... looks good tho, i dont even have a G yet but will prolly be usin this oil after the first 7500 miles or so.
Old Mar 8, 2007 | 01:04 AM
  #85
driftGT350's Avatar
cool cool... thanks gonna change it this weekend since im due.
Old Mar 8, 2007 | 01:53 AM
  #86
liquidplatinum's Avatar
This is a great thread. I hope everybody keeps it going.
Old Mar 8, 2007 | 10:39 AM
  #87
ttrank's Avatar
Grocery getter
That 5w40 Greddy oil looks like good stuff but I would rather spend $1qt less and get Motul 8100.
Old Mar 8, 2007 | 01:29 PM
  #88
jigahus's Avatar
Thanks for post. I'm now planning on using GC synth oil with an Amsoil oil filter. If I don't have to replace oil for 2 times then I'll be making money.
Old Mar 8, 2007 | 01:42 PM
  #89
Shonuff's Avatar
I agree that it can be seen as a downgrade that it's not made from a group IV base stock or whatever but at the same time if they are warranting the product the same, I can't see it hurting it's performance or durability too much. I worked as an intern at ExxonMobil where they formulated and tested the supersyn formula and I'm sure they did plenty of testing before they made the switch. They have cars there that just run 24/7 with Mobil1 (when I was there in 02, they had a bmw with over 1 million miles on it that they changed every 25K)
If you race your car or have it turbo-ed or supercharged, then maybe I can see switching, but I'm probably going to stick with it for now. At least until some real negatives are discovered from actual use of the new formula.
Old Mar 8, 2007 | 01:47 PM
  #90
LazerRed1's Avatar
Superautobacs doesnt carry the german castrol. If worse case pick it up at the bmw dealerships....
BMW oil is Castrol, but not GC 0w-30, at least not at the local dealer.
