check engine light after plenum install
Old May 29, 2007 | 02:29 PM
805g's Avatar
Hey all, i have just installed my MD 5/16 spacer.
After doing so i have realized that i am a complete retard and did not disconnect the battery prior to the install.
Now i have the "service engine soon" light lit up on my dash.
I assume it's ok to drive with this light on, yet i want ot know how to 'reset' everything to fix this.
Anyone experience this before?
Any help would be greatly appreciated so i can again.
Old May 29, 2007 | 02:35 PM
izmir41500's Avatar
G35driver Addict
first check all the hoses and connections. do all the resets at the end of the MD instructions. problem fixed.
Old May 29, 2007 | 05:22 PM
joe603's Avatar
I got money on your MAF being faulty....
If reseting the ECU doesn't fix it, take it to a dealer. Keep the install work to yourself.
Old May 29, 2007 | 05:23 PM
Hi-TechG35's Avatar
^+1.
Old May 31, 2007 | 09:18 AM
Hydrazine's Avatar
Did you touch the TB butterfly valve at all?
If yes, that could do it. Try the reset procedures.
If possible, also try to find out what the code number is. A local auto shop may be able to help.
Old May 31, 2007 | 12:09 PM
805g's Avatar
tb butterfly valve?
Old May 31, 2007 | 12:47 PM
G35kidd's Avatar
Originally Posted by 805g
tb butterfly valve?
tb= throttle body
Old May 31, 2007 | 06:01 PM
Dsskyline's Avatar
What happens if you touch (move) it? What is the reset procedure for the TB valve?
Old May 31, 2007 | 06:24 PM
Hydrazine's Avatar
The procedure is outlined in the downloadable installation manual shown on our website.
If you push on the valve, it can off set the calibration.
Tony
Old Jun 1, 2007 | 04:23 PM
allendoc's Avatar
Stickied in this forum is the quick way to reset you ECU with the Gas-Pedal. Timing is important, but it is better than reprogramming your radio.
Muski_G
Dec 1, 2023 11:11 AM
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
