How to correctly reset the ECU?
Old Aug 24, 2007 | 07:36 PM
vbx's Avatar
vbx
Is there a fuse I can pull out to reset the ECU?
I know for my s2k, all I have to do is pull out the "main" fuse, wait 5 mintues, put the fuse back in and turn on the car making sure not to step on the gas, or mess with the climate control. Let the car run for 10 minutes to let the ECU re-learn everything, then turn of the car and I am good to go.
How do I do this on the G35?
Old Aug 24, 2007 | 07:39 PM
Jason@Riverside's Avatar
With the consolt system at your local dealer IMHO....
Old Aug 24, 2007 | 07:41 PM
vbx's Avatar
vbx
I'm thinking, I can just disconnect the battery for 10 min, reconnect, turn the car on and let it run for 10 min then I would be good to go..
Old Aug 24, 2007 | 09:42 PM
cungkpham's Avatar
https://g35driver.com/forums/engine-drivetrain-forced-induction/6526-easy-ecu-resetting.html
Old Aug 24, 2007 | 09:48 PM
glennNtexas's Avatar
Works, did it this morning
Old Aug 26, 2007 | 09:24 PM
joe603's Avatar
The easiest way is to disconnect the negative battery terminal and pump the brakes 10 times. This discharges the ECU capacitors and clears any SES faults.
Old Aug 27, 2007 | 11:01 PM
ZeeOne's Avatar
The easiest way is to, start your engine and turn it off, do this 3x and with the forth start you're ready to go. Edit: I do not floor the accelerator
This method works well, especially when your ECU goes into fail safe mode on the highway/street. That was my problem whenever I boosted without switching off the VDC, especially from a standing start.
G
Old Aug 28, 2007 | 12:53 AM
bull3t's Avatar
+1...
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
MThawkins86
Oct 24, 2015 02:07 AM
vamarris
Sep 26, 2015 12:56 PM
