nismo thermostat
it's a mechanical thermostat therefore it opens up coolant to certain parts of the engine when triggered. if you replace it with the nismo then it will open up at a lower temperature. if it gets really cold where you are then this may not be a good upgrade for you.
http://autos.yahoo.com/maintain/repa...ques019_2.html
here's some info on mechanical thermostats.
Originally Posted by OCG35
I'm not sure about the coupe but the sedan thermostat open at hotter temp (180 I think?)... I bought an OEM 350Z (170F) thermostat - much cheaper than the Nismo (which isn't worth the price IMO).
The one you got is not necessarily just an OEM 350Z at 170F but it's the same on the 350z, G35 coupe, and 6MT G35 Sedan. The Automatic sedans have a 180F thermostat.
So if this OP has a 350z/G35/6MT Sedan then he/she already has the 170F one. The Nismo would be the next step cooler.
Originally Posted by civic4982
The Nismo one opens up at 155F or 68C
if you have an '04 coupe AT then the nismo thermostat would be your only way to upgrade.
the one you currently have is the 170F one and it's the same as the 350z/G35 coupe and 6MT G35 sedan.
Keep in mind though that you need heat to get your engine up to running temperature. I really am of the belief that hitting the thermostat is probably one of the last things to do on the list. there's much more worthwhile mods out there that will pop out good power like motordyne's products or others. for $140 + shipping the thermostat really won't show you anything impressive unless you're tracking the car. My assumption is that one won't experience a ton of heatsoak unless the car is being run hard for long periods of time.
The following 2 users liked this post by civic4982:
matdaddy (12-23-2011)
thanks for the info
well, i really like the amount of power that i am getting right now is perfect for me. The car is perfect to drive in city. I don't need too much power, but i do want to upgrade the car so that it will be even more joyful to drive the car. Do u have any suggestion? i would really appreciate
i was thinking of getting the Nismo differential and the heat soak cover with the Nismo thermo stat.
i don't need power, i just want to improve the performance of the car.
thanks
thanks
Originally Posted by gary c
The Nismo Thermostat isn't a great mod for the
street.......bad idea!
Originally Posted by jonnylaw
a stat is only gonna help if u have an efficient cooling system to beginwith.
![Roll Eyes (Sarcastic)](https://g35driver.com/forums/images/smilies/rolleyes.gif)
why? aside from difficulties in colder weather and alterations in fuel economy what other "bad idea" reasons are there that you've come up with? those are the main important ones that come to mind.
what makes your modified cooling system so much more vastly efficient that it gets gains with a stat? what logic have you come up with that makes a factory cooling system that is "inefficient" not be improved by a lower temperature thermostat.![Roll Eyes (Sarcastic)](https://g35driver.com/forums/images/smilies/rolleyes.gif)
Ummm. Have you taken a look at the stock radiator and compared it to a quality aftermarket one?
Way to resurrect an old thread. If you really think that buying and installing a thermostat that opens up at a lower temp. is going to help you with cooling on stock parts, you are mistaken. But hey, go ahead and buy a $45 part and install it and tell us how it helps your stock setup
