engine oil.. need suggestions
Old Nov 3, 2007 | 09:59 PM
dan|el's Avatar
alright, so my 2003 6mt with 30,000 miles on it has the oil consumtion issue. i took it to the dealer and they ran the test after a 1000 miles and it burned 1 qt so they said they wouldnt replace it yet because that is still considered normal for the car. total B.S. right? but anyways my question is could i step up the oil to keep it from burning so much? Maybe use 10w30 or 10w40. i live in las vegas so it gets pretty damn hot out here. i currently use 5w30 penzoil. it doesnt bother me that i have to check my oil level, it is just kinda embarassing when i drive and there is smoke coming out of the pipes. is there anything i could do to help?? thanks in advance!
Old Nov 3, 2007 | 10:34 PM
Scrooge's Avatar
What color is the smoke ???
Old Nov 3, 2007 | 10:39 PM
dan|el's Avatar
its white with a blue tint at times... mostly noticable at night when somebodys behind me and their headlights hit it. also when im at wot it comes out the exhaust. it is not consistent but it happens enough to bother me.
Old Nov 7, 2007 | 02:29 PM
g35ctuner's Avatar
i thought only the rev-up's had the consumption problem....>????
Old Nov 11, 2007 | 09:20 PM
cimabeu's Avatar
White smoke usually means that there is water leaking into your combustion chamber and it comes out as steam (unless the steam is only there when you've started the car and before it warms up to get rid of the condensation): blue typically means that you're burning oil. Burning oil can come from various places (e.g., timing is off, not all gas is being burned due to spark malfunction or dirty plugs, oil seaping into combustion chamber past rings, etc.). This may require some detective work on your part, especially in having your compression checked.
With respect to water in your chamber, this is another detective project for you. Typically this is as a result of condensation from sitting overnight or from doing only short runs of <10 miles. One solution is a short trip of 30 miles or more at a good speed to cleanse out the condensation. But there may be other issues, such as a gasket leak from the cooling system to the engine compartment.
Good luck.
Kng0fHrts
Sep 15, 2015 05:40 PM
03sedang35
Aug 29, 2015 07:56 PM
KevinnnVo
Jul 28, 2015 06:29 PM
Kal Hamm
Jul 24, 2015 08:55 AM
