Idler Pulley Removal Mod with Pics
Originally Posted by QuadCam
I just like posting pics of my timing cover.....soemday I'll actual build this motor.
plus losing that dead weight on the car means I can eat more donuts.
How heavy is the pulley tho? since for ppl with UR pulleys, we have to go custom on belts, but I think it is worth it as long as it is paired up with a normal belt replacement job
Btw, I thought the 2004 also have mechanical fans!!? or they are just driven not by that idler pulley?
ah ha....so that must have been the original purpose of having that pulley there. I believe Infiniti put electric fans in on the 2003.5 cars, and have never used that pulley since.
Tim,
You don't need to pull the motor. it is easily accomplished with the motor in the car. Hell, I didn't even scrape a knuckle. (that's a new one for me.)
Tim,
Oh I know, it was because the motor will be out soon anyway.
it is a 060455.
if you forget, just ask the salesperson for the size of standard length belt. then, tell him that you need a belt 1" shorter.
I believe the stock belt is 46.5." The stock part numbner is a 060465. this one is 45.5" long.
