Idler Pulley Removal Mod with Pics
Old Feb 1, 2011 | 01:16 AM
  #61
AARONHL's Avatar
WTF 2 days???????
Great job
The SNOW might change that!
Old Feb 1, 2011 | 01:23 AM
  #62
AARONHL's Avatar
Does the pulley spin when you remove the first 4 bolts? If so, any ideas to keep it stationary when using a regular breaker bar and socket?
Old Feb 1, 2011 | 09:01 PM
  #63
Frankieg35's Avatar
Can u rent a pulley puller??
Old Feb 1, 2011 | 10:28 PM
  #64
QuadCam's Avatar
You don't need to remove the pulley from the pulley bracket. Just remove the 3 bolts that hold the bracket onto the front timing cover.
If you want to remove the pulley from the bracket, you need to use an impact wrench. otherwise the pulley will spin as you are trying to loosen the bolts. I suppose you could loosen the bolts to the pulleybefore you start the removal process for the pulley bracket. The tension from the serpentine belt should be enough for you to break the pulley bolts loose.
Old Feb 2, 2011 | 01:22 AM
  #65
AARONHL's Avatar
Thanks for the info!!!
Old Feb 2, 2011 | 07:20 PM
  #66
Blue Dream's Avatar
I drove ttrank's car solo
Woo hoo got mine in today, thanks Nissan!! Damn thing is almost 1/2" thick.
Old Feb 3, 2011 | 03:25 AM
  #67
JBF's Avatar
JBF
AARONHL, were you serious about mailing your extras out? lol
Old Feb 3, 2011 | 01:43 PM
  #68
AARONHL's Avatar
Sent you a PM!
Old Feb 3, 2011 | 06:20 PM
  #69
AARONHL's Avatar
Soooo mad, he said back order and he would call me. Not sure when I'm getting them!!
Old Feb 3, 2011 | 07:25 PM
  #70
Blue Dream's Avatar
Sorry to hear that man, that sucks.
I'm surprised mine came in so fast.
Old Feb 3, 2011 | 07:28 PM
  #71
Frankieg35's Avatar
U could just cut it off your old bracket..
Old Feb 3, 2011 | 07:50 PM
  #72
QuadCam's Avatar
EXACTLY!!! It takes about a minute of time with an angle grinder to complete.
Old Feb 3, 2011 | 08:17 PM
  #73
AARONHL's Avatar
I know, I'd rather not touch the original parts. It probably just has to come from a different warehouse...
Old Feb 3, 2011 | 08:27 PM
  #74
Frankieg35's Avatar
Is rather get the spacer also.. Cutting the bracket is a if u have no other option..
Old Feb 3, 2011 | 08:31 PM
  #75
AARONHL's Avatar
Of course, I don't see why he wouldn't be able to get it. Blue Dream had no problem..
