How loud is your electric cooling fan and how long does it stay on?
Old May 7, 2008 | 11:41 AM
ttrank's Avatar
Grocery getter
Yes, dual electric fans on all sedan after 03 (03.5 and up).
Old May 7, 2008 | 11:51 AM
infinitialex's Avatar
you sure its after o3.5? because my sedan has no doggy door on the back so i figured it was an 03.5 but who knows..
Old May 7, 2008 | 02:07 PM
VernSchillinger's Avatar
Not true. I have an 03.5 and it has the belt driven fan. Believe its '04 and up.
Old May 7, 2008 | 02:12 PM
istan's Avatar
I have aftermarket FAL fans on my AMS radiator. They are a little louder than the stock fans but push a lot more air. They don't come on too often. I did wire them like the oem fans to come full-time on when the A/C is on.
Is yours wired:
AC on=Both on
First Temp sensor reached (I think 190s or so)=Both on?
That's how my FAL and AMS is set up
Old May 7, 2008 | 02:53 PM
ttrank's Avatar
Grocery getter
Sorry about that.
ttrank's Avatar
Grocery getter
Originally Posted by istan
Is yours wired:
AC on=Both on
Yes mine is just like that.
Old May 7, 2008 | 05:42 PM
hmm so if mine turns on at around 204 degrees or so is that too high? mine is wired in to original aux fan on the 03s so maybe since it was only aux fan its set at higher temps?
Old May 7, 2008 | 05:45 PM
puting in a thermostat at 170 instead of stock 180 would help maybe?
Old May 9, 2008 | 12:04 AM
ttrank's Avatar
Grocery getter
IMO it can't hurt.
Old May 9, 2008 | 02:05 AM
DaveB's Avatar
According to the G coupe FSM I have, the dual electric fans are set to run on low at 203 degrees and high at 212 degrees. I don't think adding a 10 degree lower t-stat would make a lick of difference.
Old May 9, 2008 | 02:36 AM
ttrank's Avatar
Grocery getter
If your thermostat opens earlier it can help keep things a little cooler. The other option is to change out the thermostat on your fans and have them come on ~170-180.
Old May 9, 2008 | 12:56 PM
my fan is wired into the factory harness, no separate thermostat here.
nettcar
Aug 25, 2024 11:59 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
gatorglaze
Sep 10, 2015 12:03 PM
Machine Head
Sep 4, 2015 07:22 PM
yassy
Aug 3, 2015 12:24 AM
