AEM Wideband
Old Jun 6, 2008 | 07:30 AM
ForcFed's Avatar
AEM Wideband
Getting ready to install the AEM wideband. Can I splice into the factory wideband rather than weld in a new bung? Or will that affect impedence and voltage, throwing off the sensor?
Old Jun 6, 2008 | 06:04 PM
Canadian's Avatar
Canada, eh?
You have to weld a new bung.
Old Jun 7, 2008 | 10:20 PM
ForcFed's Avatar
I traced the factory wires to the ECU and spilced into them there. Works like a charm with no adverse affects. So there is no need to weld in a new bung on a car with a factory wideband.
Although I don't know how this would work with a system that has an interface like an Innovative o2 setup. But the AEM UEGO works flawless.
Old Jun 7, 2008 | 10:24 PM
ForcFed's Avatar
BTW, I have the necessary wiring information for anyone interested in doing this themselves.
Old Jun 7, 2008 | 10:59 PM
GreenGoblin's Avatar
The goblin resurrection
o well i did it the hard way, can you pm the diagram anyways
Old Jun 7, 2008 | 11:03 PM
express705's Avatar
we fail.
Old Jun 10, 2008 | 04:50 AM
2slo2bfurious's Avatar
Did you splice a wire for only the 0-5v input (if so which terminal number is it?), or did you splice all 5 signal wires? (if so do you know which colors/terminals correspond with which wires to the uego?)
I'm trying to see if there is signal wire that goes from 0-5v that I can splice a digital A/F gauge into, so far no luck going through the wires that are for bank 2....
Old Jun 10, 2008 | 06:57 PM
ForcFed's Avatar
I spliced all five wires. Here is the wiring to make an UEGO work.
Make sure you disconnect the battery and unplug the ECU first
Don't just follow my diagram(unless you don't mind running wires all the way through the engine compartment to the harness), be sure to check my work as you go. I found the necassary wires back at the ECU side with my digital multi-meter, checking for continuity with proper colored wires between the ECU and the o2 harness.
As far as the 0-5v wire I didn't log voltages when I was testing. You can find it with the engine running probing the wires with your digital multi-meter, never test with an analog meter.
Old Aug 20, 2008 | 08:47 PM
civic4982's Avatar
this should be stickied.
I'm going to try to do the same with my PLX wideband and use the stock ECU
Old Aug 20, 2008 | 09:04 PM
civic4982's Avatar
so you went by the color of the wires from the wideband already on the car right and traced them back to the ECU wires?
then you looked at the snap in plug that came with your AEM I'm assuming and spliced it in while at the same time measuring to be sure that proper voltage was going through ?
oh and my car has 4 o2 sensors, which is my wideband?
Old Aug 20, 2008 | 11:07 PM
ForcFed's Avatar
Voltage was always fine though I never did any resistance testing, I have had no problems. The readings seem very accurate, pretty much stoich at idle and cruise.
Old Aug 20, 2008 | 11:18 PM
civic4982's Avatar
hmm if only I could figure out what matched up on my PLX unit to your wiring diagram.
Old Aug 21, 2008 | 08:40 PM
ForcFed's Avatar
Take the wiring harness from your PLX, make note of which color wires it crosses over to at the sensor harness. Now do the same with the factory harness. Now just look at what you've written down and wire it up accordingly. Make sense?
Kelvin Style006
May 23, 2016 03:47 AM
9tray turbo
Sep 29, 2015 10:22 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
mrxkenny
Aug 17, 2015 05:52 PM
G35Sask
Engine - Intake/Fuel
Aug 1, 2015 11:16 AM
