best performance N/A upgrades
  #76
Old 10-25-2010, 06:05 PM
OCG35's Avatar
^^^ this is interesting... so dealer said you have OEM vlsd?... I'd be curious to know if this is true - according to everything they released in print vlsd was not offered in 03-04 AT... there is one guy a while back who insisted they were offered - but when I asked for reference to someone that had it, the thread stopped (go figure).
If you have a chance' lift your car from rear differential and turn one of the wheels... make note of which way the opposite wheel is turning and post up.
As to shorter gears - yes you'll probably need different LSD... I'm not certain you currently have vlsd (doubtful) but even if so replacing with better isn't a bad idea (since you're swapping gears anyway)
  #77
Old 10-25-2010, 10:55 PM
bigballer8's Avatar
Originally Posted by OMG35S
Would you like to share what kind of mods you are running?
I'm also interested in knowing the best performance N/A mods for the G.
I would assume:
MREV
Spacer
Exhaust (Which?)
Test Pipes / HFC's (Which?)
Intake (Ztube + K&N DROP or Stillen?)
4.1 Gearing
UTEC - Tune
If you have the rev-up motor you should be able to pull on the 07' 350z's...
Out of this I got 4.1 Gearing and UTEC. Thanks for the advice. Probally will look into it.
  #78
Old 10-25-2010, 10:59 PM
bigballer8's Avatar
hey noone mentioned this but does underdrive pulleys kits make any difference?
  #79
Old 10-26-2010, 02:02 AM
Ginevan's Avatar
I'd like to know this too.
Smaller diameter=less material used=less rotational mass on the motor and serpentine belt. This helps horsepower, but underdrives your accessories (alternator, A/C compressor, Water pump). I could be wrong in this, but I believe it's hard to find a truly balanced aftermarket pulley.
  #80
Old 10-26-2010, 02:35 AM
herrschaft's Avatar
Originally Posted by BazookaJoe
Im a noob when it comes to rear ends. So this maybe a stupid question. I currently have an 03 AT with LSD. I would like to change out the gears for something taller. Does this mean I have to purchase the LSD again with the new gears or the LSD I have work with the taller gears? Thanks in advance.
This link should tell you whether you have an open or lsd diff:
http://infinitihelp.com/models/index.htm
I think your better off replacing you current pumpkin with a shorter geared lsd.
This thread contains good information regarding different diffs and how to swap them out:
https://g35driver.com/forums/drivetr...tial-swap.html
When I had the UR underdrive set installed, I didn't notice any difference. Car dyno'd the same too.
  #81
Old 10-26-2010, 11:06 AM
BazookaJoe's Avatar
Great Links Thank you. 3.7 from a 07 w/vlsd really looks like the best swap for me.
It did come with the sport package, which I believe gives you the vlsd. I will be putting the winter tires on this week. I will be sure to spin the wheels while its up and see. I will let you know. Thanks OCG35. I really enjoy reading your posts. Your so wise.
  #82
Old 10-28-2010, 09:10 PM
ladyblueG35's Avatar
not for nothing idk if must be something about my car idk because i havent been beat by a "z" yet and my car is pretty stock. knock on woods.
  #83
Old 11-02-2010, 10:51 AM
BazookaJoe's Avatar
Put on the winter shoes Last night, spun the one wheel and the other turned the opposite way. 2003 Sedan, Auto, Sport package = VLSD. Hells Yes!
  #84
Old 11-02-2010, 01:17 PM
OCG35's Avatar
if they turn opposite directions you have open diff. With VLSD they would turn same direction.
03-04 AT sedans did not offer VLSD.
  #85
Old 11-02-2010, 04:51 PM
Ginevan's Avatar
hahaha
Dunno why but I found that to be hilarious.
THMotorsports
Suspension-Vendor
257
12-18-2018 05:43 PM
Video Share
01-31-2017 04:00 PM
prinny
11-22-2015 11:07 PM
NyCrAzY
10-01-2015 09:19 AM
Quick Reply: best performance N/A upgrades
