resets???
Old May 17, 2004 | 12:16 AM
g35c6sp's Avatar
resets???
is there any advantage to the Accelerator Pedal Release Position Learning, Throttle Valve Closed Position Learning, and Idle Air Volume Learning (Throttle Position Learning)....
in the DO IT YOURSELF forum???? and what do the mean by "Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound." on the Throttle Valve Closed Position Learning step.... is it with the car in the off position??? any help would be great
thanks
MIT
Old May 17, 2004 | 04:46 AM
Msedanman's Avatar
O.F. Administrator
Re: resets???
Yes all the reset procedures are useful and advantageous. They all make sure settings are the way they should be and that your ride functions and performs optimally.
"Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound." --- when the key is switched from the on to the off position, the throttle valve makes a loud and distinctive 'clickety click' sound.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old May 17, 2004 | 10:05 AM
cato's Avatar
SouthernComfort Moderator
Re: resets???
I personally have never heard this "clickety click" sound and
have done all four resets several times. If you reset the ECU
by touching the + and - battery terminals togeather as
InfinitiTech has instructed, everything gets reset at once.
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals<P ID="edit"><FONT class="small"><EM>Edited by cato on 05/17/04 07:06 AM.</EM></FONT></P>
Old May 17, 2004 | 10:42 AM
InfinitiTech's Avatar
Re: resets???
There is no performance advatage to do ing the throttle pedal reset. It is only performed if you replace your throttle body unit or gas pedal assys.
Infiniti Gearhead
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
MThawkins86
Oct 24, 2015 02:07 AM
vamarris
Sep 26, 2015 12:56 PM
Blindside360
Sep 18, 2015 09:00 PM
