oil filter
Old May 18, 2004 | 08:23 PM
REH195's Avatar
oil filter
I am going to switch to Mobil 1 at my first oil change. Based on oil filter comparisons the Mobil 1 filter is the best. However, the recommended size is M1-108, which is only 2-1/4 inches long. The DIY on oil changes said to use M1-108 or M1-110. Will the M1-110 fit? I believe bigger is better.
Old May 19, 2004 | 12:31 AM
NYCXLR8's Avatar
Re: oil filter
I went through the same problem. I looked up the specific part number for the G and spoke to some of the service folks over at Grubbs. They recomended staying with the 108 filter as it is the designated model for our cars.
Bigger might not be better. It could affect oil flow and pressure. mho
2004 G35c 5AT/Prem Pkg/18" Tire Opt/Aero Kit/Clear Sides/Pedal Kit/Tint/Z-Tube/K&N Drop-in
Old May 19, 2004 | 02:00 PM
avs007's Avatar
Re: oil filter
Put in the M1-110 and be done with it... I did... It's not going to affect oil pressure. Give me a break. The ingress and egress opening are the exact same size on the two filters. Those are basically the only things that will affect oil pressure. Especially since we are talking about a system that takes 5 quarts of oil, and the difference in filter size is maybe 1/2 cup.
Old May 20, 2004 | 10:36 AM
spendgy's Avatar
Re: oil filter
Exactly. Although the additional filtration surface is only marginal, why not get the slightly larger for the same price? I threw in a K&N 1006 that is the same size as the M1-110.
KruZZe
Feb 27, 2023 05:04 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
vamarris
Sep 26, 2015 12:56 PM
