Hard Clunk and High RPM ?
Old Oct 16, 2008 | 04:17 PM
jutn35's Avatar
G35 Coupe
Exclamation Hard Clunk and High RPM ?
So today after work, i turn the car on, and i notice i higher engine noise than before, and i look at the Speedometer and its idling at 1K rpms and a little higher? Is that normal, i dont think so. And when i shifted into Reverse or Drive, the car had a hard clunk feeling when shifting ??? so whats up
thanks
Old Oct 16, 2008 | 05:23 PM
OBG3506's Avatar
Abs?
Old Oct 16, 2008 | 05:25 PM
mIKE's Avatar
It's colder? =X
Old Oct 16, 2008 | 07:39 PM
jutn35's Avatar
G35 Coupe
Originally Posted by Mike@RiversideInfiniti
It's colder? =X
its colder ? it was like 75 degrees out
Old Oct 16, 2008 | 09:11 PM
Darkstar752's Avatar
Were you parked on a hill or a flat level surface?
Old Oct 16, 2008 | 09:42 PM
jutn35's Avatar
G35 Coupe
flat level surface, i just turned it on, and i heard it louder than normal, and was idling at 1000 plus RPM, then shifted into Reverse, and i felt the car jerk or drop a bit, but the second time i turned it on , it didnt do it anymore ??
Old Oct 17, 2008 | 12:20 PM
Telly9987's Avatar
did it do it again? have u started the car sinec then? same noise?
Old Oct 17, 2008 | 01:52 PM
mIKE's Avatar
Can you replicate the problem you had?
Old Oct 18, 2008 | 02:50 AM
jutn35's Avatar
G35 Coupe
no today after work, same place i park, same temperature around 70 plus, hasnt happend since (knock on wood)
Old Oct 18, 2008 | 02:51 AM
jutn35's Avatar
G35 Coupe
no , like today i was waiting for it to happen again, but i guess only that time .....hmm makes me wonder, i hope its not the tranny
Old Oct 18, 2008 | 03:06 AM
mIKE's Avatar
If you can replicate it, then someone (including us) can diagnose it. Until then, keep driving unless you get a check light or something.
Old Oct 19, 2008 | 02:25 AM
jutn35's Avatar
G35 Coupe
thanks, i can always count on you for good info
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
magnetism80
Feb 1, 2019 10:00 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
Machine Head
Sep 4, 2015 07:22 PM
Kicknshift
Sep 3, 2015 09:35 AM
