Custom 3.5" (90mm) CAI in the works
Old Nov 25, 2008 | 07:40 PM
Canadian's Avatar
Canada, eh?
Originally Posted by MixturePinoy
your throttle body is still the same size though, you are going to see minuscule gains if any. Not just that, but you would also have to upgrade your internals, ecu, injectors, etc. for the extra air it is recieving. this mod is a FAIL
Though I do think this is a COMPLETE waste of time and money, but you don't need anything that you said you need. With boost, you don't need to upgrade your internals, or injectors with some kits. I'm at 7psi on my TT setup with stock injectors. Stock internals. The only thing he might have to do is get a reflash to take advantage of anything he is doing.
Other than that, he'll be fine. But he is not going to see any gains a popcharger and z-tube wouldn't give. Which is basically nothing.
I'm sorry OP, but no point in really doing this. But, do what you want. Post the results you get.
Old Nov 25, 2008 | 10:59 PM
jonnylaw's Avatar
You run TT @ 7 psi on stock block on stock injectors? No fuel return system/upgraded fuel pump/fmu?
Mind sharing your numbers and the cycle duty of your injectors? I'm surprised your stock setup is providing you with enough fuel.
I'm not trying to be d*ck or a doubter, I am genuinely interested.
Old Nov 26, 2008 | 12:21 AM
Canadian's Avatar
Canada, eh?
Yep, TT on 7psi making 355whp on a CONSERVATIVE tune. 23k boosted miles, 1 track day, 5+ autocrosses. Daily drive, hit boost almost everytime I drive.
I have the upgraded fuel pump the JWT kit comes with and an FMU. No fuel return system, and won't be getting one. I'll stick with an FMU when my built motor comes too. I have no idea about the cycle duty, don't know how to check that. The stock JWT is known to be able to work fine without any new injectors. Most JWT kits are done on stock injectors. If I were to turn up the boost and make more power, yes I'd new new injectors.
Old Nov 26, 2008 | 12:46 AM
jonnylaw's Avatar
understood, thanks for sharing. Sounds like you've got a great setup (good power, proven reliability), and the capability to do more when you are ready
Old Nov 26, 2008 | 02:31 AM
Andrei's Avatar
Originally Posted by _jb
Great job designing and machining that adapter plate.
I don't understand what you're trying to do with it though. If you decided not to use the larger MAF housing, why do you need an adapter?
The adapter was for the MAF housing I had which I wont be using anymore so no adapter will be made. This is an example of what adapter I needed in 3.5". http://www.cattman.com/img/prod/dsc_...%20adapter.jpg - that one is 3"
The flange will weld to the 3.5" aluminum piping I have and the MAF sensor will be directly in the pipe.
There will be gains even if the TB is 3". There will be more gains once the turbo will force air through 3.5" piping and into the 3" throttle body.
Injected Performance ran the 1/4 in 8 sec with 3.5" piping an a stock TB.
Actually I talked with Hal from IP and he said they are running a 5" MAF pipe and it goes down into a stock TB
Old Nov 26, 2008 | 02:37 AM
Andrei's Avatar
Thank you for your input.
Extra air when a car is NA never hurts anything. It will run lean for a while before the ECU can adapt with the intake.
Extra air when a car is FI hurts everything without SOME of the things you listed.
There are plenty of people running custom intakes like the one I'm making with good gains. Especially F bodies.
Old Nov 26, 2008 | 11:10 AM
Canadian's Avatar
Canada, eh?
No problem, and thanks
Sorry to put the thread OT
Old Nov 26, 2008 | 12:17 PM
ttrank's Avatar
Grocery getter
Originally Posted by Andrei
I dumped the MAF housing and went to a MAF flange for the sensor. Much more simple.
Did you get that from SFR? That's where I got mine.
Old Nov 26, 2008 | 01:42 PM
Andrei's Avatar
Yup. $45 shipped. An aluminum plate to make a couple of those is $55 shipped.
Old Nov 28, 2008 | 05:37 PM
_jb's Avatar
_jb
Photographer
SFR = Speed Force Racing? I looked through their site, but didn't find any adapter brackets to match your pictures. They also don't seem to have a search tool.
I did find a nice 3 inch intake tube at SFR's site... with the adapter already welded in... would be nice for people wanting to increase the intake size a bit over stock.
I'm looking for a larger intake tube for my NA G, but was thinking that the plenum inlet and throttle body would both have to be the bored to the same diameter to do any good. From your (and Hal's) data, it looks like that may not be the case.
Interesting thread...
Old Dec 2, 2008 | 01:37 PM
Andrei's Avatar
Today the fittings shipped that weld to the piping for the breather hose on the stock intake that goes into the plenum.
Old Dec 2, 2008 | 05:40 PM
MyocyteX's Avatar
There is some hate on this thread. Some doubters for sure. I say, even if it doesn't perform better than the z-tube and pop charger, It will look great!
Do you weld aluminum?
And does the aftermarket make a larger bore throttle body? Maybe that should be your next project! Custom throttle body FTW!
Good luck!
Old Dec 3, 2008 | 01:59 AM
Andrei's Avatar
Isn't there in any thread I start?
That depends entirely on how the pipes are routed. It will most likely be in front of the grill.
Not yet but I will. I'm waiting on the spool gun.
There is the TB from the VQ40 that might work and it's 3.25" but then I wouldn't be able to the use the AAM 3" TB spacer for my turbo.
Good luck!
Thank you.
Old Dec 8, 2008 | 12:27 PM
Andrei's Avatar
Switched from black couplers to red since I need some color in my life. Right now I'm still waiting on the spool gun so I can get started.
Vacuum caps
Old Dec 15, 2008 | 09:48 PM
  #30
MyocyteX's Avatar
More more more. :-)
