Is royal purple the most superior oil out there?
Quick question: For those of you who are using AMSOIL, how often are you changing your oil? The reason I ask, is because the Amsoil Sig. Series 0W-30 recommends to change every 35,000 miles or 1 year which ever is sooner. (under NORMAL driving conditions) OR 17,500 miles or one year. (For SEVERE driving conditions) How is this not cheaper?
People are coming around though, just like they did with bias-ply tires vs those new-fangled radial tires.
As you correctly point out, using AMSOIL synthetic motor oils and AMSOIL Ea oil filters saves a lot of money vs other oils. However, many people are reluctant to accept change, even if it is a massive improvement, are still stuck with the oil drain intervals of 50 years ago and the 3,000 mile drain pain, even though it is causing damage to their expensive engines.
But I'm curious. Exactly how is this statement true?
Correct me if I'm wrong, but when your car sits overnight and cools down, all the oil drips down into the oil pan. Therefore, when you start your car everyday it will be dry for a while until the oil starts to flow. How is that any different than changing your oil?
And since Amsoil recommends a periodic oil filter changes on their extended life oil programs, everyone is sitting in the same "oil starvation" problem upon startup.
Nice catch Canadian.
It's all so subjective. Each person has different driving habits that dictate different oil change intervals. I used to have a GMC Sonoma pu with the 4.3L V6 (runnin' SOB), it was a company truck and I changed the oil religiously every 3K. ALL my driving was highway. I put 5K a month on it. The oil change guys would say, "why you changin' it dog, this stuff looks new". I could have run that dino oil for 10K easy. That's because I get the motor hot and run it for at least 2 hrs everyday. Someone that gets in and goes 1/4 mile for a beer run, then 1/2 mile to the wing place the next day and does this all week, only puts 50 miles a month on it, is just asking for trouble if you don't change it every 3 months or less. Because acids and sludge build up in a cold motor. EVERYONE needs to take their car out and run it on the high way at least 30 minutes EVERY WEEK.
Hey all, I have used Royal Purple products for over 15 years. I have many testimonies from numerous people about its positive atributes.
This past summer a friend of mine with an '07 Vett did a heads up dyno run test on his car at OCCorvette in Lake Forest, Ca. (which is now out of business
). the test was using the factory fill, Mobil 1, against Royal Purple products. Three dyno runs for each phase to get an avereage. After the base line runs, changed the engine oil only with 5/30 wt RP oil. Average gain on rear wheels was 7-8 HP. Changed the trans and rear end for total gain of 17-18 HP !
That's cheap horsepower and that's not over conventional oil, it's bettering Mobil 1.
The shop used Royal Purple in their full race cars and very modified street cars. Royal Purple makes "Racing oils" , but they used the street oils in the race cars...said it lowered the race oil temps by 50 degrees, held pressure and they had all the horse power gains and no wear problems. They did not find a need to spend more on the full race oils...the street oil beat all the other options. That was against Elf, Mobil 1, Red Line.
I've got real people and dyno reports, not opinions and gossip. RP works and is well worth the money. It's only a few bucks more than Mobil 1, are you kidding me with the value of the Nissan engines?
). the test was using the factory fill, Mobil 1, against Royal Purple products. Three dyno runs for each phase to get an avereage. After the base line runs, changed the engine oil only with 5/30 wt RP oil. Average gain on rear wheels was 7-8 HP. Changed the trans and rear end for total gain of 17-18 HP ! That's cheap horsepower and that's not over conventional oil, it's bettering Mobil 1.
seeing the user rating and first post makes it very difficult to give any amount of credence to a pro review (of any product)... it's too clear that there is an agenda from the post and that is to sell RP.
I'd be interested to see what other posts are made and in what threads - if none, it’s shady (IMO).
We all know the advertizing campaigns for all the oil companies… forums like this one is for community enthusiast to share their real world experience from using different mods/products. I always get miffed when I see a single post or 2 relating to one product only. Pulse Plugs did it, R2 intakes did it, now RP is doing it.
https://g35driver.com/forums/search....archid=6489216
Sure, he hasn't been here that long, but I don't think he has an agenda. Heck the way RP is lauded on here you would think that it's God's gift to the motoring world.
I don't quite think that's fair. Did you even look yourself before you posted this?
The last sentence of your post confirms what I am saying... I'm referencing the guy a few posts up that is pitching RP.
