Harm in a bad ECU reset?
Old Jun 2, 2004 | 07:23 PM
GraphiteMoxie's Avatar
I just installed the K&N drop in filter and despite seeing a post from some folks thinking that an ECU reset isn't needed, I decided to try the gas pedal sequence. I don't think I got it right, the SES light blinked a few times but I'm not sure it was at teh right time. I tried it again and got a different blink,
Is there any harm in performing a bad ECU reset?
Old Jun 2, 2004 | 08:09 PM
jran76's Avatar
Re: Harm in a bad ECU reset?
There should not be. Were you able to reset the ECU in the end?
2004 6MT Sedan-- Diamond Graphite
Stoptech 13" Brake kit-- Nismo S-tune Suspension
2003 Nissan 350Z--SOLD
Old Jun 2, 2004 | 08:54 PM
I'm not sure. How would I tell? One time after I finished, the SES light started to blink fast and on the other it went from a slow blink to not blinking.
Old Jun 21, 2004 | 02:39 PM
Beantown's Avatar
Try removing the battery leads positive first and then negative, touch them together for 10 seconds and reconnect in reverse order. I tried this and it seemed to reset the ecu for me after installing the Injen CAI.
Old Jun 21, 2004 | 06:56 PM
lucidazn's Avatar
Wait, how does that methid work?
'04 Ivory Pearl G35 coupe 6MT Fully Loaded /w Navigation
Old Jun 21, 2004 | 08:17 PM
Q45tech's Avatar
Ecu constantly resets its adaptive memory [short term in seconds; long term in minutes/miles at cruise speed] to compensate for changes in atmospheric pressure [rain storms, going up down mountains] and temperature changes.
Where people got the weird idea that a reset would last long is unknown? Or that it would be effective for more than a few minutes shows they don't understand how the OBD2 ecu works.
A 1% flow change from a CAI is roughly the same as the temperature dropping 11F or decreasing the driving elevation by 333 feet............as far as the MAF and ecu are concerned.
Old Jun 21, 2004 | 08:36 PM
DED's Avatar
DED
They got it from the same place they got the idea that some ground wires would help something.
From the top two threads.
Add a wire, and reset your ecu, and golly, you'll have a monster on yer hands!!!
Giddyup!!
2004 G35C 6MT Black. Killer.
Old Jun 21, 2004 | 08:38 PM
So you're saying we should be resetting the ECU when we go down hills? How about down freeway ramps?
Just kidding...thanks for the response. I see now that many claim the ECU reset is not needed and haven't touched mine.
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
reaper76
Sep 20, 2015 11:59 AM
Blindside360
Sep 18, 2015 09:00 PM
