Rev vs Non-Rev
Old Jan 2, 2009 | 12:55 PM
OCG35's Avatar
Originally Posted by driftsucky
So, between the two, is there a REAL WORLD difference? Whether it be performance, reliability, or anything in between, do the motors hold up. I ask because my ONLY experience is with the VQ35DE. It held up fine under what I put it through and I summise that any advancement would be okay; especially given that the next car will not be thrashed upon as my Z was.
I also may want to boost it somewhere down the line. I remember when the Z came out (and maybe two years into it) any type of boosting really required you to reinforce the bottom end whether you planned on making a lot of power or not. APS's TT kit was the only real bolt on kit on the market at the time and that only made about 330-350rwhp at best. I know there's a lot more out there now, and I may not even do all that, but I guess I want to know what I'm in for if I go with an 05+
the rev-up does have stronger rod bolts and oil pump... so for higher reving (bumping the rev limiter) or going boost it could be a better choice... If/when I move to another VQ it will be the HR.
If you are choosing between 2 used cars DE rev-up vs non rev-up, I'd go with which ever one is a better deal (based on miles, condition and price)... other factors aren’t enough to chose one over the other.
HR wasn’t a part of the original question - but if you throw that into the mix, I'd get HR (that’s a whole other topic).
Old Jan 2, 2009 | 01:38 PM
djamps's Avatar
I'd check for oil consumption issues before buying the rev-up -- well either for that matter but it seems to be mainly affecting rev-ups. My non rev-up doesn't burn a lick of oil.
Old Jan 2, 2009 | 02:02 PM
driftsucky's Avatar
Before I buy, I'll check all of that out. I doubt it'd be much of an issue that I could really check. Oil burning isn't normally a quick inspection thing. I'm not terribly concerned about it though. What I end up wanting to spend is really going to determine what I'll settle for. If I get an 06/07 with 20k miles, it better be problem free for the most part. If I get an 03/04 w/ 50-70k miles, then I'll expect to have to go over a few things. Even if I didn't have to, I probably would at that mileage just because I don't want to have to baby a car. Not that I wanna beat the snot out of it, but I use my vehicles.
Old Jan 5, 2009 | 04:34 PM
nibble's Avatar
Does the revup motor have a higher redline? If so, then it should theoretically have higher top end horsepower:
Horsepower = RPM * Torque/5252
06g35
Feb 14, 2022 05:59 AM
Thebaws11
Jul 2, 2021 11:36 AM
Thebaws11
Nov 30, 2016 12:54 PM
mbe32
Nov 13, 2015 11:09 PM
vamarris
Sep 26, 2015 12:56 PM
