Help ~ Weird Idle Problem
Old Jan 15, 2009 | 03:33 PM
Tollboothwilley's Avatar
Cleaned MAF and TB
Performed accelerator pedal released relearn, throttle close position, idle air volume.
Idle RPM's dropped from 1100 to 800 after performing the idle air volume relearn 3 seperate times. (Previously idle was at 650)
Problem: During braking I can feel the transmission as it downshifts because the REVs bounce around a little.
TIA
Old Jan 15, 2009 | 04:05 PM
TwinInfin's Avatar
I've read in another thread that it could be a plenum leak?? Just saw u had the 5/8"...
Old Jan 16, 2009 | 12:59 AM
not a plenum leak, i didnt use the skunk crap
Old Jan 16, 2009 | 12:06 PM
Braintree's Avatar
Things are never what they seem- you take your car in to replace one part and another part begins to sputter. The relationship between both parts is minimal but then you assume causation b/c of what you changed. Is it possible that this is happening? For example, the fuel pressure regulator could be faulty, even tho it's not related to what you did (or a vacuum hose could be loose)? My questions would be: When does it happen? Does it happen with the engine hot or cold? Is it all the time? Is it only after a cold start-up? How long does it last? Have you changed brands of gasoline lately? Have you had other repairs performed recently? Did any episode precede the rough/surging/high idle condition besides what changes you made? Run over any possums or cats lately?
I look at the car as a series of systems-- mechanical (i.e., timing belt loose enough to cause the idle to back-up), bolt-ons (vacuum leaks at the plenum, which can be found using propane or a vacutec machine) or engine subsytems such as the ignition. Can you spot anything if you look at any codes that pop up?
Old Jan 16, 2009 | 06:02 PM
ttrank's Avatar
Grocery getter
Could be the ECU and TCU re-learning.
Old Jan 16, 2009 | 06:29 PM
No, it isn't a leak
I went to the dealership today to get some fresh oil in the tranny, they also verified to problem as a bad throttle body.
Apparently when I cleaned it it got damaged.
Damn.
They said the throttle is SUPER sensitive and this has happened a lot on cars they have seen.
What part would have gone bad and why can't that simply be fixed without buying a new TB?
Old Jan 31, 2009 | 01:22 AM
Replaced the TB, problem has not gone away yet.
wtf.
The weird part is that when I'm braking I can feel it down shift and it feels like i'm tapping on my gas pedal for half a sec because the rpms jump up 500 rpms then drop right back down.
Old Jan 31, 2009 | 11:57 AM
djamps's Avatar
Vacuum leak?
Old Feb 1, 2009 | 01:28 AM
The only thing I could feasibly see leaking would be the gasket...?
Old Feb 2, 2009 | 06:12 PM
Nope.
No leaks.
Now what?
Old Dec 19, 2013 | 01:24 AM
lazyieg's Avatar
was there a resolution to this?
leo38cheng
Nov 12, 2015 06:49 PM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
MsFitFern
Aug 9, 2015 02:58 PM
