Power outlet mod?
Old Jun 22, 2004 | 12:36 PM
gninja's Avatar
Power outlet mod?
Anyone know if there is a way to make the power outlets charge even when the car is off?? My Audi did this and it was awesome cause my ipod never died!
2004 G35 coupe 6MT premium/ POP charger with Z tube (G N1NJA)
2002 Ducati Monster S4 (S4DEMON)
Old Jun 22, 2004 | 01:00 PM
afr0puff's Avatar
Supa Dupa Moderator
Re: Power outlet mod?
Yeah... just tap an always on positive wire instead of a switched wire.
http://www.anythingbox.net
Old Jun 22, 2004 | 01:01 PM
gninja's Avatar
Can you give any more of an explanation? I am definitely no engineer.
Old Jun 22, 2004 | 09:46 PM
Sukairain's Avatar
That means you want to tap a 12V power cable in the car that's always on and not switched by power. Which mean......
Actually I also have no idea where to find this always on 12V power source near the center console or how to tap a power cable..... (Is it anything similar to the corner signal light mod? Because that I can do)
Old Jun 22, 2004 | 10:26 PM
Gordgee's Avatar
Administrator
An easy way is to use a fuse tap adapter (not sure of the term) in the fuse box. Just locate an always 'hot' terminal and plug it in, attaching your wire lead from the outlet to it.
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Jun 22, 2004 | 11:50 PM
afr0puff's Avatar
Supa Dupa Moderator
I'm pretty sure that any "Yellow" wire you will see is always hot. So when you are behind the adapter wires, look into the other wire looms and see if there is a yellow wire in them. You can then just tap into that. However, I suggest you research this a lot more if you are not familiar with car electronics. This is very dangerous what you are attempting.
Old Jun 23, 2004 | 07:41 PM
KPierson's Avatar
<hr></blockquote>
That is absolutely incorrect. Car manufacturers have NO standard to what color does what ever. The only way to tell if a wire is hot is by measuring it, and even then it may not actually be a hot wire (for instance most turn signal wires will read 12 volts until you turn the turn signal on, then it pulses).
The best place to get the 12vdc constant wire is either at the battery, or in the main harness that runs to the key switch. This wire should be a white/blue wire, and should have a 40 amp fuse on it. Remember though, that the car will probably draw around 20 amps, so make sure you don't add more then 15 amps to this wire or you might have fuse issues. For high current loads go directly to the battery and remember to place a fuse within 18" of the battery.
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Jun 23, 2004 | 11:10 PM
Casino's Avatar
^^^^^^^yea deffinitly incorrect....Yellow wires usualy stand for the sensors to the airbags i thought.....and if thats true i dont think it would be a good wire to tap into
2003 Black , sunroof, leather,
splashguards, 8 wire Hypergrounding kit, 350Z intake duct, K&N filter.
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
zcherub
Sep 10, 2015 12:03 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
INVADER_6MT
Sep 3, 2015 01:47 AM
