Seafoam? Does it work?
#66
#67
^ Jeeze Tian, I sure hope you figure out your original issue...That video above was after two months right? It just seems like you are burning oil, the way the smoke would continually pour out of the exhaust and would be a brighter white with little pedal and then space (thin out) while on the throttle...but heck, I'm no mechanic....it just seems like it's burning *something* that is continually being feed to it.....
#68
N8digity (09-19-2012)
#70
Rough idle -could be a O2 sensor starting to go. I watch my wideband and recently I have watched the car which is normally bouncing around 14.7 at idle jump up to 15.6-15.8. When it does this the rpms drop and it sounds like its struggling a little. I think its time to swap the O2's in the headers. You may be dealing with the same thing?
#71
#72
hey fellas if i only put the SF in the brake booster and gas tank, do I still have to get a oil change??? I just got a 04 coupe and I am gettin some bad gas mileage...wanna see if this would do the trick...and I just got a oil change wish i would of thought of this before the oil change.
#73
